When I start my car I get the CHECK COOLANT alarm and red warning come up. The coolant levels are fine and there is no leak. Does this sound like a faulty sensor?
If I turn the ignition off the warning mostly does not come back on till the next drive.
Leak is coming from the plastic pipe. The hose is on correctly. There is a visible leak from the plastic pipe. Coolant needs topping up daily. Looks like a new radiator?!
If the plastic 90 degree bend (red) is leaking/cracked then this is part of the radiator so yes it's a new radiator.
If the plastic connector (green) is leaking then it's a new o-ring seal.
