Car cranks but no start
sol_j
83
11
Did you get this sorted? Fault code points to it being a broken wire on the CANBUS wires going to/from the ECU.
One of those should match the PIN out on the ECU. With the battery disconnected, you should have continuity between the pins in the plugs for your ECU (CAN-H & CAN-L), and pins 6 & 14 on the OBD2 socket by the gearstick.
Note that if you test them, be sure to use fine tip probes to measure them! Don't push large probes into the sockets as you can spread the pins which will cause you even more headaches. IF you find you have a break in one of those wires, the the break is almost certainly going to be somewhere in the harness between the ECU and wherever it joins the main loom.
Full wiring diagram here https://drive.google.com/file/d/1PysokT7RjHc8Pr_nXBRA-lYKcS8UDmtS/view?usp=drive_link
If canbus looks OK, the check you have power and grounds at the appropriate pins also
If this is the case what needs to be replaced?
sol_j
83
11
Also, this is a quick summary of what has happened so far:
2002 SEAT Leon Cupra (AUQ) – Car cranks but won’t start. No fuel pump sound, no EML light, and no OBD comms. Fuses and relays checked/replaced. Tried known good ECU – same result. Dash lights up (except EML). VCDS previously showed some modules not responding, seemed to get worse over time. Suspect ECU not powering up or wiring fault (power, ground, or CAN issue), not immobiliser.
mty12345
4,133
691
bristol
Thanks for the reply! No I haven’t, waiting on an auto electrician to check it out. Does that mean I’d need a new wiring loom etc? Is this a common problem? Why would this randomly happen? Just old?
No, you can just repair the existing wire, it's just a matter of locating it. Sometimes just old and brittle, sometimes it's possible it can rub on something. Could also be just corrosion somewhere. If you look inside the plug for the ECU, is there any sign of green crusty residue? That's what corrosion looks like. If so you can clean it with isopropyl alcohol and a soft toothbrush.
If other modules were also going offline, could point to the issue being at the can gateway module.
sol_j
83
11
Yeah about 2(?) or so months before this happened the airbag light came on for the drivers side and when I went to try and fix it with a resistor I had no joy. I did notice when I scanned it at that point while doing the airbag light many modules were not being recognised when scanning like the engine control module where on vcds it would say no communications etc. I guess slowly dying(?) also when I did try out the new ecu and took out the old one, tbh it looked clean/ nothing major etc.
sol_j
83
11
Do you have a link/ part number to the can gateway module? Just in case it is that
sol_j
83
11
This is what it looked like before
mty12345
4,133
691
bristol
Looks like the gateway itself is fine. It's online and communicating, it just can't speak with the ECU. The wire is likely broken/corroded somewhere between the 2 modules. Either that or ECU is offline due to no power/ground, but my first guess would be the CAN lines. No way of really telling without measuring.
sol_j
83
11
Nah this was before, about two weeks before it died. Look at the report the aa said about my car. It doesn’t connect at all now afaik. When the recovery man came to try and fix it he had no connection. Tbh I haven’t tried it since and just waiting for the auto electrician to come out
sol_j
83
11
Looks like the gateway itself is fine. It's online and communicating, it just can't speak with the ECU. The wire is likely broken/corroded somewhere between the 2 modules. Either that or ECU is offline due to no power/ground, but my first guess would be the can lines. No way of really telling without measuring.
Iirc it was like that for many modules later on I’ll post the whole scan
Reactions: mty12345
sol_j
83
11
Update: it got fixed last week. Ended up being the front loop (?) afaik lol. The mechanic just said to me it was really bad but it won’t happen again. I did end up giving the car back due to running costs/ ptsd from the wiring issues so back with the family Skoda but this was a great experience. The insurance finishes in a few days too so lines up great. Was a cool first car but not spending much on one again like that lol. Thanks for all the help from you guys!
mty12345
4,133
691
bristol
No worries. I'm guessing (front loom) and he means the loom to the ECU
