@Tester01 Yes, I also have this and the fix is very simple. The lower seat padding is making contact with the plastic of the chair. I put in a piece of foam between it, so the lower seat padding does not make contact anymore. Solved.
Is it easy to access? Would I have to remove the seat?@Tester01 Yes, I also have this and the fix is very simple. The lower seat padding is making contact with the plastic of the chair. I put in a piece of foam between it, so the lower seat padding does not make contact anymore. Solved.
Take it you mean between here?No, just push the lower bolster to the side and put some foam in between it. if I remember I will create a picture for it![]()
Try putting a thin bit of cardboard that should help prove this is the solution.Hope it’s source of mine.
Now to figure where to buy foam I guess Amazon, tried the local shops near me nothing.
Recently I was messing with wiring in passenger door. After looking through wiring diagrams I found out that Audi A3 8V could have door lock button on them. I thought that Seat cannot be worse than Audi so I present to you modification nobody asked for
I've used door handle from UK version and due to white illumination I had to swap electronic to Golf 7 button. What is funny is that this button was already coded in my car and it started working right after I've plugget it in!
My prefacelift Cupra 280 has these buttons as well.is yours a prefacelift? As my facelift FR has those buttons already (along with auto lock when you start driving, unlock when you turn the engine off)
Both Doors?Ist Ihr Modell ein Vorfacelift? Mein FR mit Facelift hat diese Tasten bereits (zusammen mit der automatischen Verriegelung beim Anfahren und der Entriegelung beim Abstellen des Motors).
I know how it looks for you guys from UK, but the photo is from passenger side, not driver!is yours a prefacelift? As my facelift FR has those buttons already (along with auto lock when you start driving, unlock when you turn the engine off)
