Hello everyone, great to be here!
Does anyone know what could be the problem. I have coded the wireless android auto with obdeleven from the instructions. Know when I go to Full Link icon the Android Auto icon is now selectable and it takes me to the next step and that is to connect my phone to the cars wifi. I have connected to the cars wifi and bluetooth but nothing happens with android auto and it just doesn't start. With cable it works great but over wifi nothing happens.
Even tried to reboot the system but still the same.
Oh yes black box apps if you don't code it yourself per the link. That function was always in the car but not brought out. It's like a tailor making a suite but remove some stitches and it turns into something else.
There have been posts about people getting locked out when they enable these functions. They go quite when I ask. If it's factory enabled you can trust it (perhaps). One person left their keys in the car and it locked them out ?. Evident the battery went flat in the remote. The car went, OK I'll lock it. There is a lesson there somewhere.
Yeah, I used this feature aswell, but leaving the car it never locked it. Another thing is, because this feature wasn’t completely developed yet, the car would look for the key way too much, so the battery would drain extremely fast.
Just recommend using keyless access since you have to touch door handle anyway
Reactions: brabus84 and Tell
It's one of these things that should be left alone. @Syphon Cupra has it installed correctly as a factory built feature. Obviously early models didn't, so the hack was used to install it. It's no big sweet to lock and unlock the car by touch. Enabling proxy lock and unlock runs the risk of getting locked in or out by flattening the remote battery.
Apart from enabling mirrors in on lock which Seat left out of their first Kessy implementation on Seat's for the first couple of years. By 2019 they fell into line with the Vag group on one touch locking and mirrors in option which you now see on the screen. I've left Kessy alone. Newer implementations of Kessy control can turn off the virtual pedal which I think is on Syphons model. More bells and whistles on locking. Also one to turn off Kessy completely if you don't trust Kessy and cloning the key that thieves use.
Found somewhere that if your phone was already connected before obd activation of wireless android auto that you have to delete your phone from the list of previously connected devices. Deleted my phone few minutes ago and connected again and now wireless android auto works like a charm :)
Reactions: Tell
Hello all,
I already have had retrofitted travel assist on my Cupra leon '21. But it was not shown as icon on my radio display(center screen) behind "driver assists".
Now i have it on the screen also. But when changing steering response from standard middle to low or high - nothing happens.
Also when put car off and on again the option is back to middle again. So it looks like this option still needs to be activated?
Any idea where to find this in obd11?
Does anyone know if it is possible to activate colors with higher RPM on Leon, as well as on VZ5? Green, yellow, red, then red blinking.. :)
Hola a todos, ¡es genial estar aquí!
¿Alguien sabe cuál podría ser el problema? He programado el Android Auto inalámbrico con obdeeven según las instrucciones. Ahora, cuando voy al icono de enlace completo, el icono de Android Auto ahora se puede seleccionar y me lleva al siguiente paso: conectar mi teléfono al wifi del coche. Lo he conectado al wifi y al Bluetooth del coche, pero no funciona con Android Auto y simplemente no arranca. Con el cable funciona de maravilla, pero con el wifi no funciona.
Incluso intenté reiniciar el sistema pero sigue igual.
Te sale en la lista wifi del teléfono
¿Myseatxxx o mycupraxxx conectados?
Aparece en la lista de Wi-Fi de tu teléfono.
¿Está conectado myseatxxx o mycupraxxx?
Hey all - I have a 2021 PHEV estate and I'm missing heated seats. If I grab some off eBay would I need (and does it work) the ODBEleven to install them? For controls etc.
You don't need OBD11 to install a universal one you can grab off eBay, whereas you would need original parts like heater pads & climate control unit and some coding via OBD11 or equivalent, for a proper retrofit.
Thanks for replying! I'm new here and to this concept of retrofitting so I may be missing some vital knowledge on this.
I was hoping to do a proper retrofit so I can get the 'proper' experience.
I'll keep researching, thanks!
Reactions: serdar_18fr
Falls jemand Lust hat, es für mich zu versuchen, habe kein MQB EVO mit MIB3:
NHTSA Properties
Einschränkungsabhängigkeit
Geschwindigkeitsschwelle
NHTSA-Begrenzungsschalter für Android Auto ohne Videowiedergabe
An
NHTSA-Begrenzungsschalter für Android Auto ohne Texteingabe
Nicht
An
NHTSA-Begrenzungsschalter für Android Auto ohne Spracheingabe
Nicht
An
NHTSA-Begrenzungsschalter für Android Auto ohne Einrichtung
An
NHTSA-Begrenzungsschalter für Android Auto mit Begrenzungsanzeige
yed_message_length
An
nhtsa_limitation_switches_for_carplay_no_softkeyboard
D
An
nhtsa_limitation_switches_for_carplay_no_softphonekey
ypad
Nicht
An
nhtsa_limitation_switches_for_carplay_limit_nonmusical
Listen
Daten in Echtzeit
Nicht aktiviert
NHTSA_Limitation_Switches_for_CarPlay_Limit_MusicLists nicht aktiviert
Lange Codierung
NHTSA_Begrenzungsschalter_für_CarPlay_Keine_IAPAN
Anpassung
Nicht aktiviert
Hello Group Members.
I am thinking of installing a blind spot monitoring system. Does anyone have experience? If so, what do I need to know? Thank you in advance for your answers!
Replacing your current door panels with ones that include LED blind spot indicators. It doesn't have them, and it needs to be coded...Antennas behind rear bumper, antenna mounting brackets, wiring. Get your money ready, good luck
Reactions: Tell
