thanks for the tip. I managed to activate the view correctly. I changed the derivate to derivate 6.
Hey, I just enabled my Cupra display yesterday via a one-click app and saw that I have the exact same issue.
What did you mean by "I changed the derivate to derivate 6"? Is this the value of a parameter for the display in long-coding?
if the one click app does not work according to what they say it will do then you should speak with support and ask for a refund.
They can be very helpful with this sort of thing (but sometimes not)
Was thinking exactly that, so I contacted them today, but still waiting for a reply.
I hope they're willing to help
Just so you know OBD11 Run a two tier support system, if you have a Pro/Ultimate package you get high priority responses if you just have a Basic plan then you have to wait in a queue I am afraid but they are now working on Saturdays so hopefully it wont be to long.
Reactions: Tell and LeoSlo
I've been searching but with low success about the following topic.
Does anyone know how to activate the audible locking confirmation through the car's horn (considering that my car does not have the OEM alarm)?
There should be an entry in 09-Central Electrics -> Adaptation like "Acknowledgement signals". Under that, you can try to change the options with "Akustische rueckmeldung" to Active and see if it works. Make sure that you made a backup before changing anything.
Due to different platforms or hardware & software differences, Central Electrics control unit might have those options somewhere else.
Then I think that so and so person enabling beeping on lock. Quite village hear and when someone arrives with it :oops: . I reckon there might be an EU directive against it 🫣. Hence why the vast majority of cars in the UK and EU dont have it enabled.
So you're saying I shouldn't have told him how to do it?
control unit 5F
- Select Adaptation
- Select Function Configuration hmi
- Select Skinning
- Set to 2
- Select Screenings
- Set to 1
Could you please help me with the stardard value for these fields? I can't see the car image in the settine g screen on the multimedia central screen. Thanks in advance.
Kein Serienalarm = Keine akustische Bestätigung (Codierung läuft)
Watch the mirrors fold in if they auto rotate in on lock. Good visual check when you walk away and doesnt annoy the neighbours.
Ganz genau, ich bin Spanierin aus Spanien, und obwohl wir hier „lauter“ sind 😂, finde ich es in Ordnung, den Piepton zu aktivieren... Wenn Sie keine werkseitige Alarmanlage haben, piept diese auch dann nicht, wenn Sie sie mit OBD11 codieren. Der Alarm ertönt nur, wenn Sie die werkseitige Alarmanlage haben. Bitte entschuldigen Sie, falls es nicht gut geschrieben ist (Übersetzer).
I know it came up recently on this thread or another. Due to sound abatement in the EU regulations prevent the car being shipped with it. People use to the sound, demand it but swinging mirrors has the same effect. The noise of them turning and a visual check once walked away should do. I often look back, did I lock it, yes, mirrors in.
That falls into the category of one click apps where we say don't since you dont know what they are doing, you cant unravel what they have done with the coding of the car. Those that were unfortunate enough to have Excel macros dropped on them at work that go wrong and the headache of shuffling the sheet back again. No shuffling of sheets if a one click apps goes wrong. It's messed the cars coding up.
To be safe you buy the pro license and study forums with published coding on them for similar models, carefully noting what you are doing and unravelling if it doesn't work. That which you can't do with one click apps.
