the one click app are not official from OBD eleven engineers? are they unsafed?
Yes they are, but it is not possible for them to test each and every combination of control unit hardware and software possibilities and their possible interactions with each other. An app that works for almost all combinations might not work for one that wasn't tested.
ok, is possible to someone to try this modification on a seat leon mk4 fr?
central unit 17 --> adaptation --> configuration of displayable contents --> upshift display in center panel --> not display
I receive Failed
All unsafe if you dont think they have been tested correctly. One click market is designed to challenge other one click companies. If you want proper coding you code and that isn't really coding it's toggling on predefined functions that Vag have built into their systems for customisation for their own purposes. A point which people miss. Reversing out of what they have done via one click is the all important thing. Obdeleven started to use crowd sourcing to develop the one click apps which obviously means amateurs are producing the macros by scouring published mods. :rolleyes:
