I have a spare TCS mate, very unlikely i'm ever going to need it (famous last words,lol)
PM me your address and i'll post it to you.
So kind of you - thank you so much. Really appreciate it.
A delayed update on my car.
I had to postpone, so it went in on Monday & the brake master cylinder is on order from Germany, so gonna be a few weeks.
Really pleased it's all in motion now & will put it through a MOT after all work is completed 🤞
I was going to ask if u had an update as I think you said it was going in on the 22nd, thats great news in away least now you know the issue did it blow the seals on the cylinder, maybe they tried to brake the brakes by the pedal method ive done that and been ok but with reading you should one of them pumps to do it. Anyway glad to hear hopefully it's close to being on road shortly bud.
Had a few small jobs to do, had to reattach the roof lining as when we had the heatwave the front corner came down luckily just a small section. And the front speed sensor had to replace as normal did not wanna play and snapped so was able to disc off and with a small hole punch was able to get it out new one fitted and back to normal for now lol.
Thanks mate, yeah I forgot to update the dates as I wanted the car to stay in the garage until all roadworthy (fingers crossed), so re-booked to suit.
I'm counting down now, really am hoping that that day trip out in my boy is on the horizon, even driving it to the garage was enjoyable. 😊
  • Haha
Reactions: nd-photo.nl
The mk2 has it as well must have been an option from factory ?
Guess so, My Mark 3 has the same option upgrade, much better than all the modern car safety features.
now trying to get to the bottom of an issue with the car, gets to 3.5k has a hesitation then goes again. someones deleted the 249 valve and had left it unplugged ive plugged it in and its worse
You can only delete it if its mapped out (and maybe with a resistor), else you need to leave it connected and do a n249 bypass. Also check for vacuum leaks, as the 1.8T is very sensitive for air/vacuum leaks! I had a leak in a hose under the intake plenum and only noticed it after I removed the hose
