Yep that's the ones i hadYep, my "Topsport" edition also had 16" from the factory
Still cheaper than running a newer car as daylight running headlights 800 quid , locks 1k and so on and at least you no the history of your car and when you do get it back there’s allot you can do your selfI Finally have an update on my blessed car.
It had it's brake master cylinder replaced yesterday, but unfortunately when tested, the brakes were still binding once warm. The wheels were apparently moving more freely than before & can now be turned by hand, unlike before, but now they are suspecting the abs module.
They are going to look at it again next week & brainstorm possible ideas, & from what I've read there are a few more hydraulic pressure tests they can try & the push rod may need adjusting. The garage boss was very decent & apologetic, so I feel somewhat better about it. However, the expense of an abs module to be sent, tested, fixed & refitted is looking to be £400+, which is busting my budget for other things that might be needed for it's MOT.
If I listened to my head, I'd cut my losses & call it a day, but my heart is still set on getting it roadworthy.
I'll see what happens next week & take it from there, but my optimism is waning, along with my bank account.![]()
I don't understand how the abs module is related to «The wheels were apparently moving more freely than before & can now be turned by hand, unlike before» - it seems more the seized or rusted brake pads carrier.I Finally have an update on my blessed car.
I don't want to give it up, it's my pride & joy, but I don't know how much money I can keep spending to get it off the starting block. I have to run two other cars in my household & even though they are standard, my Ibiza being a 1.2tdi Copa, they are quite easy & relatively cheap to look after, just massively boring.Still cheaper than running a newer car as daylight running headlights 800 quid , locks 1k and so on and at least you no the history of your car and when you do get it back there’s allot you can do your self
I didn't think it was the abs either, but I've now had three garages say that, so i don't know what to think. I read last night, that if crud had been pumped through when the brake lines were first installed, it could have wrecked the seals or damaged the sensitive solenoid valves, although I don't know if that would affect all 4 wheels? They are all binding so the problem is brake fluid not returning & pressure building without any release.I don't understand how the abs module is related to «The wheels were apparently moving more freely than before & can now be turned by hand, unlike before» - it seems more the seized or rusted brake pads carrier.
Chin up mate, you soon be back smiling again when she's done.I Finally have an update on my blessed car.
Thanks mate. I'm just getting impatient, haven't seen my car for weeks & my hopes of taking it out this summer is beginning to look less likely.Chin up mate, you soon be back smiling again when she's done.
Is that a 3D printed dipstick holder? It doesn't seems plastic.... more metal alikeinstalled the phenolic space today and put on my newly painted rocker cover and inlet manifold, got my mate to 3d print me off a dipstick holder too.
just need to give the engine bay a good clean now and that will be me done with that. although i could be doing with some form of heatshield for the air filter if anyone knows where i can get one, ramair dont sell them seperately.
View attachment 55093View attachment 55096View attachment 55095
Ah that makes sense, seems you have everything under controlthe injectors got new orings fitted, the buckets look all good and were dry ont he car the manifold came off. before i got the car though the pvc system was split wide open causing lots of oil mist spray, that whole area under the manifold is covered in oily dirt, i'll get some good degreaser and brush it in well and pressure wash it all off and see how it comes up.
that shield looks good, i'll see if i can find the file for that or another one and can get my mate to print it off
