Ckpearce91
1,288
18
Milton Keynes
SEAT Ateca Variable Boot Floor kit DIY installation guide applicable to Pre-Facelift (2016-2020) & Facelift (2020-present).
This guide has been written to help people who have or are intending to purchase the variable boot floor kit that Seat Direct Parts have put together. Here’s the link https://seatdirectparts.co.uk/parts...teca/seat-ateca-2017-2020-double-floor-option
When I purchased this kit, I searched all the threads on the forums and the Facebook groups for a installation guide. I also emailed the supplier asking for a guide however they did not have one. The installation process is fairly straightforward but does mean cutting the carpet in the boot.
In this kit, you would have received the following:
Variable floor
2 x Side supports
2 x Union nuts
2 x Torx bolts
A few covers
Tools I used:
Utility knife (Stanley knife)
Cordless drill
40mm hole saw
25mm hole saw
Pen/chalk
Jigsaw
Superglue
Step 1: Fold down rear seats and remove boot floor.
Step 2: Offer up one of the side supports to the boot wall where the anchor point is, as the support will clip on to the anchorage point in the end. This will make the side anchor points redundant.
Step 3: You can now see whereabouts the holes will need to be cut. Mark the hole nearest to the rear of the car with chalk.
Step 4: Move the support out of the way. Lift up the carpet and get your fingers in, you should be able to feel a bolt sticking out of the wall. You need this bolt to come through the carpet and into the hole nearest to the rear of the car on the support.
Step 5: The hole will need to be about 40mm in diameter (I used a hole saw in a drill). This is to allow the plastic of the support to go through the carpet. Offer the support up again. You may need to cut some more carpet of to make it fit nicely. The bolt should be coming through the hole in the support.
Step 6: Once you’re happy with how the support sits, you can push the support on to the anchorage point until it clips in. Hold it here as it will unclip. Mark the other hole. Again remove the side support and cut the carpet. This will need to be about 25mm in diameter. Again adjustments may be needed.
Step 7: After you have cut the 2nd hole there will be a hex shaped hole in the chassis which will be revealed. Now install one of the union nuts. These go in tube end first so the lip rests on the face of hole. If the union nut goes in and is a perfectly tight fit and you cannot remove it then great. If it is loose then I would advise to remove it and put some glue (I used superglue) on the hex part of the nut and then put it back in the hole and wait the recommended dry time.
Step 8: Now you are ready to screw it in. I found the supplied bolts to be too short. I don’t know if this was a mistake from the supplier. It has nothing to do with the carpet as I checked before proceeding with the installation. Fortunately I have a van with a range of bolts spare. I found a couple of 6mm bolts with washers that are about 8-10mm longer than the original bolts. These were perfect. Offer up the support and start screwing the bolt in. Once you’ve put a few threads in, you can take one of the supplied covers and push it onto the bolt from Step 4. Push the cover on as far as you can and fold the cap over until it clips on.
Step 9: Now clip the support to the anchorage point and hold there whilst tightening the bolt up. Take your hands away and repeat on the other side.
Step 10: Both supports should now be installed. Test them with your new floor.
Step 11: Now the variable floor is done, we need to reinstall the original boot floor so that A) you have a second floor to allow for storage under the new raised floor and B) so that no items or objects fall from the raised floor down the sides into the wheel well. The original floor may not fit now due to the supports being in the way. I measured the depth of the protruding part of the support to be 2” x 2.5”. Mark this with the chalk and cut (using a saw of some kind) making sure to do it at an angle just like the support. The floor should now fit around the supports.
This is the end of guide. I hope people find this helpful. It’s not perfect but it works. I do not work in the motor trade and cannot advise on legalities with this modification when it comes to PCP or Lease cars. I know that at some point I’ll probably have to replace the carpets in the boot before my car goes back. To me this was a worthwhile modification for a car I will now have for 4 years.
that's superb. I'm new to the SEAT world so having this will make the installation much less stressful. Interesting regarding the bolt lengths. I will see what they ship when I order my kit. thanks so much for taking the time to share your experience and document it.
I'm sure a lot of people will appreciate it.
thanks
Adam.
Just fitted mine and as others have said following the guide makes it straightforward. Used longer bolts as well and superglue. Took about an hour plus superglue drying time and a coffee break..... Thanks for the guide!!
Reactions: Ckpearce91 and Tell
Thanks for the guide, just fitted mine.
The hex nuts supplied are nut rivets and require a tool to fit them securely, as they are metal, I could not fit them with a hand tool, I would advise you use aluminium 6mm nut rivets instead and you will find the supplied bolts do fit (no need to buy longer ones).
TA
Reactions: Lee01 and Tell
See this thread for the 4Drive kit, post 13. This is where the 4Drive is sold without the spare. If Cupra Ateca read all off the post for any specific issues that may have been mentioned.
See also the PDF here:
Raised floor fits fine over a spare wheel in my 22 Ateca Xperience, not sure if the 4 makes a difference in the floor height at the rear.
Hi @Ckpearce91 , got a question in reverse of this subject if you can help please, save me posting another thread...
I've got the VBF already fitted from factory, but I've taken the side supports out so I can get the high edge plastic boot tray in (575061201C). So can you guys tell me if there's absolutely anything that looks like a cover where the VBF side supports ultimately go, or is it just carpet and no plastic trim/plate? I'm guessing not as you have to cut to find the bolt hole and the union nut stubs, but at the mo there's just the holes in there and it looks a bit Heath Robinson. Cheers
Oh, and I also have a space saver 18" under the VBF for anyone wanting to know if it'll fit. It does. :)
Hello from Istanbul!
I just wanted to say a big thank you for sharing your boot floor installation experience. Your guide helped me a lot and the result turned out really good.
I truly appreciate your help!
TA
Just done this install myself and as @Masonic, says, the nuts supplied are rivnuts so will indeed need a rivnut inserter tool to do it properly rather than using glue to hold them in which will no doubt fail over time.
Cheers to the OP for the guide as well (y)
Reactions: Tell
To be fair it lasted throughout my ownership (4 years). I think as there’s no stress on those screw points the glue seal never broke. But yes if I knew at the time that they were rivnut’s I would have 100% bought the appropriate tool.
Reactions: Tell and Lee01
As they say hindsight's 20/20 vision but glad it worked for you.
It would have been nice if there was an installation guide supplied with the kit but knowing VAG, it would have said 'install the rivnuts with VAG tool 029817' or something 😆
Reactions: Tell and Ckpearce91
