Does anyone know if the full size exhaust tunnel cover fits a 4drive ST or what modifications are needed to get it to fit ??
That’s a shame, the small version hardly looks to be worth installing as it literally covers nothing up ??‍♂️
I was reading in the Golkmk7 thread that the full sized version can be installed on a 4wd an extra part is needed to be installed first (bracket of some sort) but I’ve read the post several times and can’t quite understand what I need ?
Also…… what rear suspension covers do I need for a 4Drive ST ?
My goal here is to make the underside of my car more aerodynamic as I’ve got a Remus exhaust on my R ST and it’s hurt too end performance as it hangs low and acts as a giant air brake !!!!
Wanted to install the front exhaust tunnel cover (5Q0825229C) on my 4drive ST as well.
Since it was very cheap I just ordered it. Should've read the 2nd page here :)
Anyway I don't think it works out anyway since the 3" DP sits lower than original.
There is a smaller plate, meant for the 4x4s. It's about half the plate, only attached to the front screws.
The FWD ST has no issues with the front cover due to the lack of the propshaft and how much higher the exhaust sits.
More pictures can be found in my showroom thread!
AP1GczN-SRVK3IPAqjYhYF8XwROeTAhAyb3JUGaTGuu9aC-IDMoTn2NySx2UqGfclA6w8AuimxFItN_K_LWiNaiSwI-ZiRIn_3NbMiC0EUaRIQ7KVT8s1ajCuMIkOv-vUKEWSPscv5WPXOpieHlczYYpGJdFgA=w1920-h1080-s-no
As you can see, I also have the full belly plate
AP1GczO7NW9DYJYn25dvyZ1IqgdeY2nIgnwYAe-Oq4Uckzn1oS5OcXiZC0VTwVVAJhHPA15S5tHWGaowlp_dt4BSwMyXHZz4dOgCpsTPjN-1NPJUcndwkhyHSjbazz_xnwstyL9tUBs_5YjU8_PTl2q4aC7trg=w1920-h1080-s-no
Also added the rear cover, but my exhaust melted part of it. I added some heatwrap to the exhaust and some reflective heat tape to the plastic panel, which worked out well
AP1GczP0LIkjatGc4-WprIYEHOBfFdSuCkb7oJ0TqfBHbBErA4InX6Gg9ENrRrOg6C-EeO8rFQGomJb1F0PnJgLyHVRLrZ14RCpPF4BZZFgnlT3wfDBbzxqTCnhuPDp3VMnTLyMdhGxp0NF8bw_KxV5wPOJgJA=w1920-h1080-s-no
AP1GczNd38pkjnbDELUtzywGM0_KI5iWshJp-0Ea-gbh5fjNoDZdONu8_Zd8E_-t8dmv0OyvW_Slh7mf6ibKBdjNzLT_Ecd_zfr8qUOCUA9xxTS7wKhCd5j9XSUbeM8FJfJEzBM2g37KxltzgqIkKpcnvNUlQw=w1920-h1080-s-no
@nd-photo.nl I'm not sure what its supposed to mount to back there.
Is there some middle strut I need or it kind of just hangs there? Which points actually get mounted?
Found another image on another forum which is likely the part im missing (probably 5Q0804421B):
Might be the difference between FWD and 4drive since I don't have that at all
