Well, let's see if that works...
Took the weather strip out of the car last Friday to clean it up and to check the drain holes in the bottom of the door. It rained pretty hard yesterday morning though, and I could see there was water on the sill again. Fortunately with the door card off, I could see where the water was coming through...
I didn't replace the butyl tape when I replaced the lock a couple of years ago, hence it looking a bit messy. It held fairly well up until now, but if you zoom in, you can see drops of water. When I levered the inner door skin off, water came through from the sealant below the speaker, as well as the bottom of the speaker housing itself. I wasn't any to start drilling out the rivets and resealing that, so the butyl has all been replaced, and I ran some silicone sealant around the speaker housing too.
The new butyl looks a lot cleaner now too. Don't want anyone thinking I might have done a half-arsed job of it...
After cleaning up the weather strip, I decided to put new 3M adhesive on too.
Will wait until it next rains (give it an hour or so...) to see if it's worked before I put the door card back on. Noticed while I was tidying up that the passenger front door has water on the sill now too. That's the only door that's never had the seals replaced, so it kind of deserves some fresh butyl after holding out all that time. I haven't done a front door for a while now, but I know it's easier than mucking about with that bloody peg and dowel arrangement in the rear doors...
