This is my Project inicied in 2002
Ibiza GT TDi 110cv
Alterations:
Engine:
- Oil BP Visco7000 5w40 Turbo Diesel/Sport
- Filter H58 oil, diesel and pollen - Bosch
- BMC box filter
- Catalytic Off
- EGR: Electronic Dutty-cycle Recalibrated, closed mechanically
- Specific Dump-valve for TDi's - Bonalume
- Pipes of 4mm to Dump-valve - Samco
- Valve with 2 poles of oil pression 0.3-0.15bar/0-5bar Ref: 035919561 - Buy SEAT
- Turbo VNT1749VB (Original by TDi’s 160cv)
- Turbo Colector worked, because the Windows looked too small
- Nozzles Power Plus 764 Fratelli Bosio
- Front Mount InterCooler buy Wiltec in Germany
- Diesel Cooler 330D BMW - SN 7785 587
- CCVByPass, Oil Catch Tank :brilho:
Connection to ground and suspension:
- Kit Koni Sport Regulation in height and hardness Ref:1150-5013(lowered
55mm)
- Anti-approach bar OMP Front-Up
- Anti-approach bar OMP Front-down(Charriot)
- Anti-approach bar OMP Rear-Up
- 4 OZ superleggera 7j x 17 H2 (weight 7kg)
- 4 Champiro HPZ-40 GT tires (205/40 ZR 17 84W)
- 4 Invisible valves - Eagle
- 4 screw-safety Wheel (http://www.ferreira.pt/)
Brakes:
- Discs_Front 280mm drilled and scratched - EBC
- Brake pads_Front Ferodo Racing FDS774(with competition specification)
Upgrade:
- Kit Brembo 305x28mm original from Seat Ibiza Cupra R de 2000 – Buy Seat
- Steel mesh tubes
- Brake pads _Rear Ferodo FDB7083
- Brakes rear painted with Spray Motip Vermelho(for high-temperature)
Outside:
- Solar Films Midnigth(5%)75x300_Black – Race Sport
- Remus Pan Type 813 Specified to mk2 Cupra
- Rádio Antenna (10 cm) – Race Sport
- Minimum-light with white Led's
- Medium-light with Phillips Cool Blue +20%
- Maximum-light with Osram silverstar +50%
- AeroTwin Brushes– Bosch
- Lip Leon cupra R Ref: 1ML805903 – Buy Seat
Inside:
- Range of progressive film inside the front glass – Race Sport
- Aluminum inside_Lettering (“S” in volant symbol and letters “Air-bag”) – Home made
- Turbo pressure gauge in the Pillar A – Race Sport
- Turbo pressure gauge support – Home made
- Botton on “tablier” ON-OFF with Green-Red lights for Dump-Valve TDi
- Manometer support in “tablier” Ref: 6K1 863 263– Buy Seat
- Black-mate Console for “tablier” Ref: 6K1 858 069B - Buy Seat
- Cover to to manometers support Ref: 6K1 863 253 – Buy Seat
- Oil pressure gauge VDO Ref: 6K0 919 551- Buy Seat
- Voltimeter VDO Ref: 6K0 919 531- Buy Seat
- Modified hand-brake – Home made
- Key Bridge-and-spring(from model Ibiza 6L)
- Modified up-down glass button Ref: 6K0 959 855A 01C to press centralizated close - Home made
- Cruise control (from model Ibiza mk3) Ref: 6K5 953 503AK20H - Buy Seat
- Installed maximum temperature indicator of the refrigeration circuit of the Quadrant
Audio:
- Kenwood 1724 Kcd
- 2x80W --> in doors
- 2xTwiters --> “tablier”
- 2x80W 2 vias --> tailgate
Soon:
Mount the FMIC
ECU reprogramming
Here, i let you some photos of my inicial Project and i will discribe what i will change:
Ibiza GT TDi 110cv
Alterations:
Engine:
- BMC box filter
- Catalytic Off
55mm)
Brakes:
Upgrade:
- Steel mesh tubes
Outside:
Inside:
Audio:
- Kenwood 1724 Kcd
Soon:
Mount the FMIC
ECU reprogramming
