1.2 12v k and n panel filter?
tooly1
1.2 power !
Oct 17, 2009
116
Nottingham
will it make any difference at all better furl comsumption ?
also how the air box pipe comes out has anyone modded a pipe from the front grille direct to the opening to the pipe?
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
I found a I use a *fraction* more fuel compared to the standard filter, if you click the Fuelly.com banner in my sig then you can see from the bar graph the fuel consumption change from when I put it in in August.
I found the car drives a lot smoother, there is no power difference that I can feel.
I thought about doing the behind the grill air feed thing, but again didn't think it would make any difference, if anything if the engine was getting "colder" air I thought it would only use more fuel...
.G.
tooly1
1.2 power !
Oct 17, 2009
116
Nottingham
fraction more ? madness though it would bring it down abit after all the cooler the engine the less fuel will be burnt !
joop200789
330
Barnsly
no colder the air the more dense it becomes which means theres more air, which means more fuel needs to be added to get the fuel mixture to stochametric (14.7-1 ratio) for correct buring, then hense more power but you'll not feel the defference
tooly1
1.2 power !
Oct 17, 2009
116
Nottingham
ok so its probelly not worth spending 40£ on a filter is there anything else i can do to help to get better mpg im already driving easy ! 4th gear at 30!
red_october
I tried iridium plugs in my 1.2 and a green panel filter, I also changed the fuel filter when I did a service and put some injector cleaner in the fuel tank, the total bill was expensive and the results hardly noticeable. I think the 1.2 is pretty good on fuel anyway:)
