1.2 front brake pads
Had
I need to change my front pads on my 03 plate 1.2 ibiza. Was gonna do it myself, just not sure what pads i need. Can anyone help me out?
Rosco906
1,445
Burntisland, Scotland
if u think u can do it then go to ur local motor factors and just give them the details u need to.
If u think u know what to do then go for it. If not then take it to a local garage.
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
as said a local motor factor will help you with the parts
replacing the pads is so easy even a stealer can do it, I must admit I have not done this job on a mk4 1.2 but normally one large bolt is removed so you can swing the caliper away and then slide the pads out
refitting is just the reverse but you will need to force the piston open to make room for the new (thicker pads), this is normally quite easy to do with a large screwdriver, hammer handle or somthing , just use it as a leaver and push the piston in
make sure you remove the lid of the brake fluid reservoir and you should see the fluid level go up as you push the piston back
once fitted take it easy on the brakes for 200 miles so they can bed in properly going too mad on them before they are worn in may warp your disks
should take a total novice no more than 2 hours and save yourself £50 :D
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
there easy to do if you have a basic knowledge of changing pads, when i done mine i just got seat pads as there not much more then a factors. took me like half hour to do
Had
Im based near Dartford. Shouldnt be a problem fitting em, tend to be mechanicaly minded. Got a basic knowledge of disc brakes from mtbing. Problem is im not too into car parts so wasnt sure if i need specific pads, will pop into my local car shop, just didnt want to go there not knowing what i wanted.
Cheers for the help!
