1/4 mile performance figures for TDIs
Mikey_H
258.7BHP 39?ft/lb
Feb 15, 2007
810
Buckingham
i was told cams on a tdi was a complete waste of time and money by several companies, has it made much difference??
shadowmaker
2.5TDI 228kW 587Nm@1,3bar
Feb 28, 2007
85
14,535s and 99,3mph (158,88kmh) with my 2000kg 2.5TDI T4 van. No diff lock. FWD.
Going to brake 13´barrier next season...
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Good going. I'm determined to break through the same barrier in early 2008. I also think I need more practise/knowledge of how to make a car "tick" on the 1/4 mile which will probably get me as much time as upping the power.
FabiaTDi
VT5 :D
Mar 22, 2003
152
I'm running a VT5 on stock injectors and have never had it dynoed. An estimated 220-230bhp maybe more. I'm not too hung up on the power figure unless curiosity is getting the better of me. It drives pretty well.
What is most impressive is the way it pulls after 3000rpm and holds the power/boost to nearly 5500rpm. 95mph in third no problems. Above 100mph in fourth is now something else once it gets going.
sooty22
sooty22
Dec 28, 2006
726
nera richmond north yorks
mine doesnt quite pull all the way to 5500 b0ut to around the 4800 mark seems realy strong i wil have to get my car on the rollers llards said it wil be definatley between 225 and 230 he he
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Yeah, even mine doesn't really go beyond 5000 - or at least it seems that the car is more effective being shifted up a gear at 5000rpm, and not taken any further. 5500rpm must be around the limiter on a TDI I would imagine?
FabiaTDi
VT5 :D
Mar 22, 2003
152
Yes not much point in going past 5000. Best to change up and whoosh, screeee, chirrupp off we go again..
T. Spark
Limiter on a vRS is like my FR @ 5,200rpm so interested how your's pulls all the way to 5,500rpm?
sooty22
sooty22
Dec 28, 2006
726
it was the turbo that allards advised me on which was the vt2 i think. it boosts toa peak of 30psi ans sits at a prettymuch constant 28psi higher up the rev range, my car wont push a 95 in 3rd gear even on the limiter.... unless the fabia ids geared different i dunno....
FabiaTDi
VT5 :D
Mar 22, 2003
152
I think its because the earlier vRS (like mine) had longer gearing, so thats probably why mine gets there.
martycupratdi
Newbie
Sep 2, 2004
46
Kinross, Tayside
Hi all,
I never thought that my original post would result in so much information.
I'm fascinated by the depth of knowledge that you all seem to have about your various cars, and the tuning projects that you are competently having carried out on them.
If I were to stick to diesel power and purchased a second "play car" for 1/4 mile and track/sprint use would any of you like to suggest a good base vehicle as a starting point.
I think my choices are Fabia or Ibiza, but not sure which model of diesel to start with, should I go straight for a 140 or are 90, 110, 115 or 130's good too. I gather that the 170 with the particulate filter is to be avoided, is this corrrect?
T. Spark
Current, Seat Ibiza Sport PD130's share the same gearbox ratio's earlier Skoda Fabia vRS up until the 54 plate (from what I can gather) at some point, when they changed the Ibiza to the FR and changed the gearbox, they did the same with the vRS 6/12 months later.
So anything from say a 04 plate on a Ibiza (aka a FR) has the same gearbox as a 05 plate onward vRS.
Still begs the question, gear ratio's or not, how your car goes strong until 5,500rpm when the limiter is 300rpm before?
