The Mk1 Golf 1.1 and 1.3 DO have the chassis leg mount brackets in a different place to the larger capacity engines. Not that this is anything to do with the thread...
Well, yes and no. As the 1.4 Ibiza motor is largely the same engine as the 1.1 and 1.3 engines found in mk1 Golfs, it follows that the mounts would be the same. Thus, this may explain the difference between the various Ibiza subframes. That was why I brought it up in the first place. Sorry, I didn't intend mk1 Golf engine mountings to become a subtopic...H8SV8S said:The Mk1 Golf 1.1 and 1.3 DO have the chassis leg mount brackets in a different place to the larger capacity engines. Not that this is anything to do with the thread...
jenk said:off topic sorry - ibiVR hows ur vr6 going, gona start thinking about putting one in mine after the summer.
IbiVR said:Just to throw my 2p in, why not convert it. ok Its not the most financially sound thing to do, but he didnt come on here asking advice on his finances...
Its a second car, so theres no rush, take your time, if your mate reckons he can do it then go for it - just be aware that its not gonna be as cheap and easy as you think it is, you could do it cheaper by selling what youve got and starting again... but its your car, you want more power, but you want to keep your car. fair play.
I wouldnt bother putting the 1.4 engine into to 16v. take some time and find just an engine and subframe, wiring loom etc. If you think you can just swap over and have 2 cars your gonna be dissapointed, but thats no reason not to convert yours - just you wont get so much money back.
Would i do that swap given the situation.... no, but its your car.
oo, and re insurance - i disagree that the insurance will be crippling. In my experience of engine conversions it wont be any worse than insuring a standard 2.0 16v. Get some quotes first though so you know its viable before you end up with a car you cant insure. I'd recomend HIC or Brentacre.
Tom.
First off, they're called BRAKES.dougy69 said:...breaks from mrk 2 2ltr 16v or cud i also put 20vt ones on. if so is there any benifit?? ...
Sorry, it's a pet hate of mine...will the different size input shafts cause any headaches?plus differing size clutches.just a thoughtAs I think was mentioned by someone else before, you could always use an 020 rod change box from a 2.0 8v but they don't handle big power and torque at all well.
hopkinsgm said:I'm pretty sure that one of the mounts is welded in a slightly different place - which isn't immediately obvious until you try and put a big engine in your small engined mk1 Golf. This may be of interest... http://www.clubgti.com/forum/forum_posts.asp?TID=53483&PN=1
If it were as simple as just swapping over the fuel system (which is only an afternoon's work if you put your mind to it), everyone would do it. Fortunately, it *is* pretty much that simple in your case, as a 1.6 shell has the mounts in the right place for a 1.8 engine. Good luck with it by the way...
