vngtx
what do you reckon is the limit of an 8v? i dont mean my 116k engine, if i sneezed on it, it wud probably explode. id get a low mileage one. plenty of turbo kits for them.
190 is the most ive seen
If we talk about ABF engine then one guy near me has 215HP without standalone and ITBs!
Rolling road lottery I guess then![]()
i think its all about surface area, as a larger wheel has a higher surface area = more power.
Also a smaller wheel has to turn faster putting more strain on the engine.
But that is all a guess![]()
knowing my luck would get it all done and 1 of 2 things would happy wouldnt start or would explode orrr i would get in a argument with a tree lampost or lesser car than a seat lol
copy/paste from H8SV8S
- Complete ABF
- Mild head port/Stage 1 or 2 on stock valves
- 2.5" exhaust and standard header
- 270+ or similar camset and stock valve springs, preferebly with SEAT Cupra ABF lifters as they're lighter than the VW ones
- Standalone engine management and 7,500rpm rev limit - none of this half-cocked stuff. You want your own sensors and complete freedom with tuning
- Stock intake with panel filter and cold-air pipe to airbox
- Ported throttle body
- Quality spark plugs and pump fuel
- Several hours dyno time with final mapping on the road
- Plus a few other bits and pieces
- This spec made 202bhp and 161lb/ft
Engine two:
- Complete ABF
- Same head spec as above
- 45mm independent throttle bodies with port matched manifold (if they're not direct to head bodies) - get this matching done when you get the head ported.
- Throttle body heatshield (see pic of one I designed below) or custom radiator that sits below the grille - you'd be surprised how much heat soak the ITBs get from the radiator. I don't like airboxes as they lose the induction sound, which makes Honda-boy wet his pants
- Air filters obviously, sock-style are fine but allegedly don't flow all that well - I've not had any trouble myself though
- Again, 2.5" exhaust and stock manifold
- Standalone ECU again
- 268 inlet cam and stock ABF, or 260 exhaust cam, stock valve springs and SEAT lifters
- Catch tank and quality plugs
- You need more nuts, bolts, hardware and fabrication for the ITBs
- You also need more dyno time as they're quite difficult to get mapped properly (at least, I've found this).
- This motor (admittedly running twin 268s) made 205hp & 177lb/ft and drive so much better than engine number one as the torque spread is huge in comparison.
thats a nice way to spend 2 years wages![]()
Turbo'd ABF I know of a Mk1 golf running 4wd using the rallye drivetrainpushing 410bhp! So plenty of power you can get from a 2.0 16v
the most I've read with someone using a standard ecu, ported and polished head and cams is 193bhp.
