2007 mk2 leon Fr, rear window wiper not working and both water jets front and back not working
Mar 21, 2023
Hi
so my rear window wiper is not working and both water jets front and back are not working but the front wiper works fine, I removed the rear window wiper motor and hooked it up to a 12v source, and the motor worked, I then tested the connection running to the rear window wiper motor and got a low voltage reading of 3.8V to 4V, now I'm no expert and have read on other threads that this might be because there are different speed settings on the wiper but I am still to test that, is it not supposed to be 12V?.
I have also checked the fuses in the cabin and the engine compartment they are fine(not melted or blown), so I need to check the relays ?? where are they situated ?? I have attached pics of my relay setup I have a 2007 Leon 2.0 tfsi spec: sunroof, non-xenon, 6 spd manual, and leather seats. I'm providing these specs in case anyone has the same specs to compare the relay setup
Mar 21, 2023
Hey hey! Nope, still no fix — clearly this issue belongs in the X-Files, right next to UFOs and Bigfoot. Rear window gremlins? Interdimensional glitches?
Apr 25, 2025
16
Hello guys, check my post. I found the solution. There is written step by step what you could check and what could be wrong.
