60k Service!
Essex_Cupra
466
Is this the big 1?
I know the cambelt has to be done.
Also i've recently had my ecu light on for many reasons recently all replaced i think!! (as in i can't tell if it actually is!)
But now it seems as though a secondary air pump that warms up the cat on cold starts is causing the problem? and the light is on again! But would this cause my ecu light to come on? And would this be a problem like blow my engine up!!
:confused:
Essex_Cupra
466
Got the codes if this helps
17832 P1424 035
Banki,Secondary air system, Leak Recognised,Sporadic fault
17536 P1128 035
Banki, mixture adaption (mult.)
system to lean
sporadic fault
Help please?
Chez
151
Edinburgh
Hi,
First question- service.
I recently got my 60k service which included the cam belt replacement, as well as waterpump etc which is reccomended at the time. This plus the service cost me £400.
Second question- ecu light.
I also have this persistant problem with the ecu light coming on due to the secondary air pump. I've had it tested and it works ok but still registers the fault occasionaly. Your car will still be ok to drive.
didgy2
newbe
Feb 19, 2004
422
glos
main dealer 60k service doesn't do cam belt, just had mine done, they said its 100k+ before this is done or did i hear them wrong?
60k service was about £150 i think.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
60k service is cambelt check, cambelt change is on 120k!
Got my 60k service on friday (3 k early) but gotta get it in, will be supplying my own oil, and telling them that they do nothing else without telling me!
Check the maintenance manual that came with the car, it says what's done on each service interval!
flashbsd
cambelt change is 60k, many dealers confuse it with the external drive belt.
timing belt is the important one.
Redcupra20vt
357
kent
Chez said:
Hi,
Was this from a main dealer
Paul
Essex_Cupra
466
So i should be worried about the timing belt not the cambelt?
Essex_Cupra
466
Yea my light has gone off again now and seems to going really well again!! Did you end up replacing your secondary air pump in the end?
I'm getting my ko3s and fmic etc etc ... done very soon just don't want a silly problem spoiling the fun!
Chez
151
Edinburgh
Paul
Got mine done at Star Performance.
Would'nt trust my main dealers to do a oil change, never mind a 60k service.
Air pump prob- I just get it reset everytime theres a fault. Maybe replace it one day but it's not really a priority at the mo.
mrcoyote
See no evil...
Jul 26, 2004
2,624
Essex_Cupra said:
Where is star performance? I'm in essex let the main dealer do everything!
Which one do you use? There aren't that many here are there?
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Techincally the cambelt should be changed at 120,000.
But now VAG have added that the cambelt must be inspected at 60,000 miles and 20,000 miles there after thus shifting the responsibility over to the dealer if it breaks before 120,000.
I dont know how you can check a cambelt without removing it and by that time you might aswell change it, so they get done at 60,000.
Chez
151
Edinburgh
Star Performance is the tuning garage i use which is in Kirkcaldy, Fife, Scotland.
www.starperformance.co.uk
I got mine done at 60k which was reccomended to me as the belt snaps due to the tensioner wheel siezing and stripping the teeth from the belt.
Better to spend £250 for it now than risk £1000+ if it snapped due to not doing it.
