Radek
70
Recently I found following error in ECU :
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
I'm suspecting pre-cat lambda fail , so I've logged group 001 and 032
group 032
first block 0%
second block -6,3%
group 001 lambda % vs RPM
On Ross-tech Wiki I found that specifications for normal operation are usually somewhere near +/- 10%.
Any comments ?
MAF looks fine , it shows almost 140 g/s around 4000rpm.
I had no chance to log WOT up to the redline .
Chart below has been logged in traffic .
BTW What's load % ?
Help use help you, log it 4th gear, 1500 to redline anything else is pointless really except 3rd gear and id only do one block at a time.
Log 002,003,020,114,115 & 118.
Do one or two blocks maximum then post the results using the code button, graphs are hard work to look at.
