Strange day today,
Went and rescued my dad who has been snowed in, for summer tyres the quattro is very good.
IMAG3998 by cuprajake1, on Flickr
And at the summit
IMAG3994 by cuprajake1, on Flickr
After we had returned from hunting (big shop) I got chance to mess with my wheels
In the booth prepped and clean
IMAG4002 by cuprajake1, on Flickr
Then ground coat black
IMAG4005 by cuprajake1, on Flickr
Then on with silver followed by clear coat
IMAG4009 by cuprajake1, on Flickr
IMAG4010 by cuprajake1, on Flickr
Tomorrow it will be polish the other three lips then clean the insides as once the wheels are rebuilt they will need balancing.
Jake
Did a bit more on the wheels today,
Sanded the barrels as they were corroded, then put into the booth for primer then paint, went for a gun metal finish inside
IMAG4013 by cuprajake1, on Flickr
IMAG4017 by cuprajake1, on Flickr
IMAG4019 by cuprajake1, on Flickr
Did the centre caps too
IMAG4016 by cuprajake1, on Flickr
Here are the centres out of the booth in day light
IMAG4023 by cuprajake1, on Flickr
Then this aft had a oem Bluetooth module fitted and coded. It's really surprising how much you miss them
Jake
one thing that has slightly bugged/worried me is the car feels quite notchy on the gear change, hard to get into first and second, well today I changed my gearbox oil, which made a slight improvement nothing drastic, so I used a guide on fine adjustment of the linkage,
what the guide doesn't show is how to get to it so:
take the gear lever off, stupid clip.. I replaced the metal clip with a hose clip after,
then you have to pull the foam out, and the ashtray with 2 8mm bolts,
push the ashtray back, there's some rubber matting, fold that back, and under it a plastic cover with 2 10mm bolts,
undo these and then you can see the linkage,
use this vid
https://www.youtube.com/watch?v=HOm9gQKFX8M
its made a massive difference,
ive also found a few little niggles to sort to keep me busy haha
