Russellg911
Hi
I have a 54plate LCR with approx 13k miles on the clock.
For a couple of months the car has been having imtemittent episodes of sluggish running. The main symptoms are:
Spongy throttle response when on the move (it's normally very crisp and takes off like a scalded cat even at half throttle)
Lacking progressive pull above 4krpm (i.e feeling held back) but then a sudden snap of boost (as if something has come unstuck and freed itself)
On occasion there is no turbo 'nudge' at 2.5krpm and the normal whistling sound of the turbo cannot be heard as the car pulls through the rev range.
So far I have done the following:
Seat dealer done a check for fault logs - nothing found, keys handed back.
I unplugged the MAF and went for a drive - not a great deal of difference - car felt smoother but a bit down on power. The following day I plugged the MAF back in and after a day of driving the car felt fantastic - very responsive and pulled swiftly through the rev range. It made me realise how it should be. That same evening I done a vagcom run with Mark (mork) and all seemed fine; the MAF showed good readings. Then after a few days the car lost it's edge again and has been on and off since. The car was recently vagcom'd again for a couple of hours driving and again no faults were logged and all readings appeared normal. One thing we noticed however was that there was a very fast regular pulsating 'clicky' sound coming from the engine part circled in the pic below:
Am I right in thinking this is something to do with the EGR? If you touch one of the pipes near the circled object the clicking sound stops - the other day though it could be heard from inisde the car. Does anyone have any idea what may be causing my car to feel like it does? This has really got me scratching my head and although the car is reliable (i.e always starts ok, doesn't kangaroo or stall), I do feel there is a problem that needs sorting and this is not a case of having got used to the power.
As a side note, the car generally pulls well when flooring it through the gears (although this is not my typial driving style) and is always very crisp and responsive the first time I put my foot down on my journey home from work - the car then (normally) becomes sluggish after. I've noticed that manipulating the throttle on and off (once past 4krmp) can sometimes 'snap' the boost back into place. This is definately not turbo lag and is like something becoming unblocked.
Thanks for any help and all the people that have answered my PM's so far.
Russell
Russell
