Stealthdave
299
Car is coming up to the end of its 3 year warranty.
Just noticed the following bubbling on two seperate spots on the same alloys
THESE PHOTOS ARE NOT OF THE SAME BUBBLING, BUT 2 DIFFERENT INSTANCES.
Anyone know if this is covered by the warranty?
1st instance:
2nd instance:
I have had this isssue on another marque of car and intially the warranty claim was refused as it was said to be caused by stone chips hitting the side and then corrosion setting in. I did argue this should not happen on a car just over a year old and in the end Cadillac agreed to refurbish all 4 wheels.
Deffo worth putting a claim in and saying you have never used corrosive cleaners ect.
had this with BMW Mini and they refused and stuck by their guns too. Ended up sitting in the show room and refused to leave til I spoke to the dealer principle. Still no joy, I wish you the best of luck!
done 25,000, it is only on one wheel
Thats how many the Cadillac had done I also used the line that I had a BMW of similar millage driven on the same roads with no such issues. But it is a hard one to do as looking at your pictures it is a stone chip that has casued the intial damage and allowed water ingress.
The design yoou have is also more prone to stone chip strikes than other designs after alengthy talk with a Cadillac/Saab Engineer. In the end you may have to pay the £50 to get it refurbished or get a good will gesture. I could not get my wheels replaced but Cadillac did pay for the wheels to be refurbished. To be honest the powder coat finish is actually thicker and stronger than the orginal paint and laquer finish.
Sorry, should also add that these are two different spokes, and not the same...
We also have a mini cooper that is 5 years old which apart from the missus kerbing them have DO NOT have anything liek this bubbling on them.
If SEAT won't do anything, is it going ot get any worse if I dont get it fixed?
It will slowly bubble through further yes as the corrosion progresses so does need sorting sooner rather than later. But is more unsightly than anything else.
I had the same on my old EP3 Civic Type R - Honda replaced all 4 wheels with no arguments.
Doubt SEAT would do this as they are tossers. (well the garage I use are anyhoo)
My alloys have covered 40k and are over 3 years old, no signs of corrosion at all - if the dealer shows you another 3 year old car with no damage your claim is going to be shot down in flames.
I think to get your dealer to make/contribute to repairs you need to choose your words carefully. Have you always had your car serviced there? Including the brake fluid and air-con? Which dealer is it? Maybe someone else has dealt with them with a similar problem?
Car has always been serviced by a seat dealer, but NOT the one I bought it from.
Had the brake fluid done at 20k service as recomended. Never any mention of servicing the aircon.
My warranty runs out 9th January, booked in for service on 4th so will metnion it then.
this happened to a mate's alloys ONLY he had the wheels for 2 WEEKS ! i think it a defect myself ...classic case of contamination with the top coat chemically reacting with something underneath !
You will have a tough case, they will say that you used an aggresive wheel cleaner - very hard to prove otherwise too. Had a simlar case on VW Passat ALL 4 wheels blistered would'nt even go 50/50?!
Yeah, not holding out much hope either really, but it really is crap.
1st instance:
2nd instance:
Replaced one wheel on mine under warrenty, done similar miles to you car nearly 3 year old
Just stick to your guns and argue like hell youve nothing to lose
Just spoke to the dealers and apparently the alloys are only covered for one year and they won't fix it...:(
Is this something an alloy refurb company could probably fix? I've noticed that where the worst of it is that it is started to peel away and is down to the bare...
Yeah an alloy wheel firm will sort that a piece of cake, just make sure its a powder coat rather than a re spray, as it will bubble quicker if just sprayed.
Wait til the winter ends now and then get it done, if it gets worse don't worry as they will sort it.
Jim
