I wouldnt of bought that sealing tape it will happen again after a while. seal it up with clear silicone, sorted!!!!!!
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Isn't this seal modified now, the old stuff is like foam?
Pics as requested:
Hi mate, you getting the water sitting on cill/rubber then?
If not could be bulk head if not or the engine loom cover (uses the same seal)
Pics as requested:
Thanks for the pics mate, might be an idea if i get the same problem in the back.
Cheers... let us know how well it works after some rain which im sure you wont need to wait long for![]()
That looks horrible i would no way do that to the seals.Lee, I blasted them with a high pressure hose and nothing came in, you could see 2 lines running down the sill, exactly where the slits were, no noise from the outside either after drying the car off on the motorway after i washed it, no wet feet while opening the door either, from what i saw , no water was sat on the sills. will report back in a week as we're due some rain being up norf!
exactly what i said when i mentiond how i cured it
lee may i plz have your crown as god pls lol
sorry to you all for my crapness with the pics though
yes it looks naff but id rather this than have the car stinking of damp, going out 10 mins early in the morning drying the inside of the mindows and scraping them in winter (iv been there), not getting wet feet when i open the door and not having newts making them self at home lol
no extra noise and no drafts, the seal on the door its self goes over the slit and more or les stops it but wont push up to tight on the slit so the water just runs away
balls to 200 quid to seat and balls to any other fixing tape and sealent lol
