Unfortunately that didn't cure the problem.
I didn't think to stop and check which Leon model you have and whether they are all fused the same way, as my sig says I have a 2010 FR CR170, maybe your fusebox is different. Did you look to see if the unit power lights went off? Obviously you can always disconnect the negative terminal of the battery.
Reactions: kewe
Yes mines a 2010 FL tsi. Tried removing F8 15a. fuse Have also removed and reconnected iso connector on rear of unit. It just won't boot
