Anti roll bars
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Im pretty sure my PD130 has a 18mm front ARB and no rear ARB,
If i installed the Front 20mm ARB off a Fabia would my handling become worse or better?
Also if i fitted the Jabba ARB off the Fabia, would this increase or decrease the stability off my car?
Adam
JBS Sales
Eibach do a ARB that is 22mm for the front, make it nice and stiff!!
I have heard that rear ARBs causes oversteer :D
Mike
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
ive narrowed my optins down to the 20mm Cupra one or the 20mm Favia Vrs one,
Although the Vrs one is cheaper,
Will it make my car understeer tho?????
JBS Sales
It will take out a little more body roll and make the steering more direct and shaper.
I don't think it will cause the car to understeer.
Mike
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Right then...
Shopping list:
Fabia VRS front ARB
Cupra Front wishbone rear bushes x 2
Mike... Ill be in touch
maxcars1
735
IIRC Stony the vRS and Cupra share the 20mm, 100pd 18mm and the FR/Sport are 19mm. Got the cupra one on mine and payed £40 +vat. It does help, and I'm considering the Jabba Rear ARB now to compliment my Cupra one and Eibach Pro Dampers.
gazjones
i though the fabia arb was thicker than the cupra one but if they are identical and fabia one is cheaper think ill go for that one will it fit straight onto my fr without anything else, if not what else do i need cheers gaz
gazjones
seems very expensive though and is it a perfect fit for the mk4 and how difficult is it to fit? i also want to reduce roll at the front of the car as well so thatswhy im loking into the fabia front arb as well
Jan 29, 2003
915
Manchester
Yup.. is a perfect fit for mk4 too (i saw one on the M60 that had one)
it gives a extra level of cornering-confidence.. i rate it above the eibach suspension ive got on my car!
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
its good for a fabia due to the fabia having a thicker front arb,
my ibiza only has a 18mm arb so having the jabba arb would make it tail happy!
