OBD scanner Palm software :
http://www.auterraweb.com/lib/auterra/ScanTool20.prc
Due to size constrains I can't post the view of the diagram in jpg format.
The interface diagram is in postscript format.
there are 2 ways to see this:
1. send the file to a postscript printer
2. get postscript viewer installed in your pc, I installed GSview 4.1 - PostScript previewer. Needs Ghostscript 7. from
http://www.ghostgum.com.au/ . With this software you can print postscript files on non-postscript printers.
The OBD connector pinout can be seen at:
http://www.obdii.com/connector.html
The interface I built does not use the L-line portion, only the K-line. L-line was used in OBD I cars (ie: my old 1994 Golf) to manually get the diagnostic codes thru the check engine light.
The interface diagram is courtesy of Steffen Koehler a nice guy I met through newsgroup rec.autos.makers.vw.watercooled a few years back.
This interface has been tested with Steffen owns software which supports OBDI cars, (pre 1996 ) the hardware interface is the same at the electrical signal levels, the actual protocol, transmition speeds have changed to OBD II (post 1996 cars).
This harware interface is assumed to work with the ISO9141 OBD (used by VAG cars), this means it only uses voltage levels to transmit digital 1s or 0s. Other manufacturers use pulse wide modulation, and another kind I can't recall right now (more info on
http://www.obdii.com )
W a r n i n g:
There is +12V battery voltage and ground present at the OBD connector, these plus the signals come from/through the ECU, you run the risk of at least blowing a fuse, So.... unless you know what you're doing leave it alone. Otherwise.. enjoy!
