herbert
Anyone find out an more info on being able to close the windows from the Key fob rather than using the key?:cheers:
Share info? :p And is it possible for the LC?
It's a sad day.. but even my dads Focus 2.0 Ghia can do this remotely! My LC should be more then capable :<
Vag Com time?
I think its possible with VAG COM, do a search for KVW 100 on here ( which costs £30) but there is also a thread to do it with VAGCOM
I found the thread to do it with software but you need a serial cable and not usb, which I have, darn it.
hi. Vagproducts.co.uk do them for £25.99. Take 2 minutes to install. I have one and am vey pleased with it. No wiring to do. Windows go up on 'LOCK' and can be rolled open on 'UNLOCK' by keeping hold of unlock button. Recommended.:clap::clap::clap:
I've got AutoWindows on my, an it's well cool.
I've got the Vent option, and it's perfect for those hot days when you're in the office.
Just set it up when you get in, and it'll vent the windows about 1inch when it gets too hot in the car, and then close them again if it gets too cold, or rains or gets too dark...it more expensive than the KVW100, but still a good option.
Shame you have to pick between venting and reflex mirrors.
Do you have to enable the vent option when you lock the car or does it stay active all the time?
You can just lock (single push of lock button) or Vent (push unlock then lock)
It is fairly adaptable however, so most uses are catered for...
I don't have active wingmirrors :cry: so doesn't matter in my case.
