Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Most people use the Nomad one
http://www.nomadracing.com/catalog/index.php?cPath=56&osCsid=2ef0944cbb795dab68c64ac24d87027d
are those ones fitted using velcro do ya know or is it proper fittment??
Sory to jump in but does anyone know were to get the 4mm hose/tube from as I want to fit one this weekend and have not got time to order. Tried b&q today but could not find anything
I fitted my boost gauge today using some washer hose from halfords(stupid I know its melted allready but at least its got a route now). It was boosting at 18/19 and I was wondering can you tell bhp from this, as when I bought it I was told arond 260 but there was no graph?
Also if your following that guide above I'd say your better off T'ing the Boost pipe as close to the inlet manifold as possible and not the dump valve end![]()
What he means is,he stood watching smoking a fag while i fitted it
Funny as feck that it melted,i should have drilled into the body and fed it under the scuttle panel.I guess that heat shield was there for a reason![]()
