boost pipe upgrades tdi cupra
Jun 7, 2006
2,983
Norfolk, Norwich
i remember redcupraguy from st ives mentioning about boost leak from the intercooler pipe or something or other..
i was just wondering is there like a full pipe kit i can buy to replace all my pipes with uprated ones
thanks
Smee
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
no will do in future when i take 100+ quid to sfs performance but at mo no...
when i do i'll get a list of part number etc for the furom
you having problems? i've changed a couple for silicon and all my clips for rally grade and now it seems it's pretty tight apart from the connection to the turbo!
Jun 7, 2006
2,983
Norfolk, Norwich
i dunno... i need to get vag com or find some one local with vag com and do some runs... i might be paranoid but something dont sound right drives fine tho
Smee
redcupratdi
Oct 13, 2005
755
cambridge
to take of your bumper it is easy to inspect, but i had a burst hose that took me ages to locate..
they just not good enough for 30psi!
Triple D
smee, why dont you get over to allrds and get them to make you up some custom pipewrok from the turbo, to the fmic then from there to the inlet manifold. i have it from my turbo to the first section of forge pipework then from the last bit of forge pipework to the inlet manifold. looks loads better than the standard rubbish anyhows.
redcupratdi
Oct 13, 2005
755
cambridge
stay away from allards heard bad things ;)
Triple D
Nah mine has a little bit of silicon hose on the turbo, then metal pipework from there
Triple D
yep well i changed a few when i put the forge fmic on, and then allards changed the rest when they did the turbo
