My Sparco seats have mounting points for side or base mount. If your seats have fixings underneath you should be ok.
Mine were originally side mounted but we needed adjustment for the driver so checked with Sparco who pointed out that the seat we had also had mounting holes underneath which they then supplied a runner for.
It sounds like Corbeau don't do this then? And probably not advisable if they don't recommend it.
But I don't think any runners are FIA approved. Seats have to be fixed if you're racing
If you're not racing you don't need that approval anyway. We run our 350Z for corporate track day hire which is why we need the adjustable seat. To be honest it would be fine for racing too but rules is rules I guess!
I guess you have cut the old standard fixing points out as omp make seat mounts for them I had them in the Leon they also fit the mk3 Ibiza I wouldn't run with the adjustable ones they sell tho they will make you sit up so high , your be better off getting a plate across the two bars that are welded in so you have more adjustment
Hello again world!
Restarting this venture again, I'm in the process of dedicating the car to track, I've just got my hands on a couple of slicks and a new set of wheels
Before I get her on track I want to do the following;
- Adjustable seat runner
- 2 more slicks
- OMP Steering wheel & pop off boss
- Get 2 piece floating disks made to match Brembo's
- Get front pads to suit (suggestions needed for great track pads - not used on road)
- Remove turbo/ manifold and get it redrilled to accept M10 nuts to hold her down! Also re-seat exhaust
Potential future thoughts are to look into SQS gearset and roll cage. Baby steps though hey
Great to hear Joe,
slicks and an 02j didnt alex strip 3rd on a set of 888's never mine slicks
Great thread..
You're on the right track (excuse the pun )
This QR boss throws the steering wheel out another 60mm so bear that in mind.
I'm selling this 300mm OMP wheel by the way as I've gone up to 330mm.
Good choice on wheels too. With slicks it'll be awesome but be aware some trackday organisers don't allow slicks at all, and some don't allow them unless you have a rollcage.
R888s are fine though.
AP have a bespoke floating or bolted disc service but Badger5 may do the bells you need.
I'm just fitting some 355mm 2 piece APs with F50 Brembos to the 350Z.
Have you tried Carbotech pads? http://www.carbotech-europe.com/
They're expensive but worth it and they'll even recommend a compound for you based on your car's spec if you email them.
Have a word with Hispec.
Ive just ordered my AP rotors from them (they have a 5% discount atm aswell) as they make them up with 28days and was half the price of proper AP rotors.
Iirc if you have the size and pcd's (wheel bolts and bolts for the bell) they will make you a set
