√дLİC
Hey ppl, this is a brilliant site, brownie points to whoever set up & runs it. :clap: Anyways I've decided to reap the benefits of your combined expert advise.
I have bought a set of 17" TOORA T940 's they have the following measurements:
PCD: 100, Rim width: 7.5J, 4 stud, offset: 35mm, diameter 17", tyres 205/40/17
I know they came off a mk3 seat ibiza cupra, the Q. is Will they fit on a 1.4 S reg mk2 ibiza SXE as I don't know whether the wheels will fit under the arches? r the spaces for the wheels to fit under deeper on a cupra? Will they rub, do i need spacers? HELP the newbie!!! :redface:
They will fit fine, not sure on scrubbage with 205 tyres on, but 7.5J will go under there no worrys!
wheels will sit in 5 mm more than your current wheels although yours is a 1.4 so unsure on standard offset.
Hope this helps.
yeah should be fine only difference is the width of the wheels, i have the mk3 cupra alloys on my mk2 and they are fine but those are wider
there are quite a few people running that size on a mk2 afaik and have no problems, only thing you may get is rubbing if you decide to go lower
