Can someone take a look at these?
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Had the car remapped and have done some logs to make sure Im getting the best from it....
Ive logged 003 and 020, 115 and 031, 118 and 032. 002 and 114.
I know a little about logging but if someone could take a look and tell me if they think the map could be improved or adjusted in any way.
From the logs boost is peaking at 1.5bar and dropping to 1.1bar, there is a strange dip in boost just around 5k RPM. Is this due to the high CF's?
Let me know
Code:
	Group A:	'115				Group B:	'031
		Engine Speed	Load	Cmd Pressure	Press @ Intercool		O2S1 Voltage	O2S2 Voltage
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP
	4.16	1320	77.4	1240	1070	3.86	0.938	1
	4.77	1400	81.2	1280	1110	4.47	0.984	1
	5.37	1480	84.2	1730	1150	5.07	1.016	1
	5.98	1560	87.2	1860	1180	5.68	1.016	1
	6.57	1640	92.5	1960	1230	6.27	0.984	1
	7.18	1760	95.5	2050	1280	6.87	0.977	1
	7.79	1880	101.5	2130	1340	7.49	1.016	1
	8.39	1960	109.8	2240	1420	8.09	0.969	0.953
	9.1	2160	122.6	2350	1550	8.78	0.953	0.953
	9.7	2280	139.8	2350	1720	9.4	0.961	0.953
	10.3	2480	163.9	2360	2000	10	0.945	0.953
	10.91	2680	191.7	2350	2420	10.6	0.953	0.953
	11.51	3080	191.7	2320	2540	11.21	1.008	0.953
	12.11	3560	191.7	2310	2540	11.81	0.922	0.953
	12.72	3440	191.7	2300	2520	12.41	0.961	0.953
	13.42	3720	191.7	2300	2480	13.12	0.93	0.953
	14.02	3960	191.7	2300	2490	13.72	0.945	0.953
	14.63	4160	191.7	2290	2480	14.32	0.953	0.953
	15.23	4400	191.7	2280	2420	14.93	0.961	0.953
	15.83	4600	191.7	2250	2390	15.53	0.961	0.953
	16.54	4840	191.7	2260	2380	16.24	0.93	0.953
	17.14	5040	191.7	2240	2320	16.84	0.922	0.875
	17.74	5240	185.7	2210	2270	17.44	0.844	0.836
	18.35	5400	131.6	2180	1660	18.05	0.782	0.828
	19.05	5560	131.6	2180	1660	18.76	0.821	0.821
	20.06	5720	152.6	2150	1820	19.76	0.867	0.875
	20.66	5880	174.4	2170	2170	20.36	0.922	0.914
	21.26	6000	173.7	2140	2170	20.96	0.93	0.93
	21.98	6120	145.1	2070	1930	21.58	0.86	0.813
	22.67	6200	109.8	1150	1380	22.28	0.789	0.766
Code:
	Group A:	'003				Group B:	'020
		Engine RPM	Air Mass Flow	Throttle Opening	Ign. Timing		Cyl #1	Cyl #2	Cyl #3	Cyl #4
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °ATDC	STAMP	 CF	 CF	 CF	 CF
	0.28	3320	90.89	100	23.3	0.58	3	0	0	3
	0.89	3400	23.42	16.1	9.8	1.19	0	0	0	0
	1.49	3400	2.36	5.9	2.3	1.78	0	0	0	0
	2.08	3360	5.89	6.3	2.3	2.4	0	0	0	0
	2.7	3360	24.39	17.6	35.3	3	0.8	0	0	0.8
	3.3	3440	72	34.9	27	3.6	0.8	0	0	0.8
	6.92	4040	164.44	100	8.3	6.62	0	0	0	3
	7.52	4320	169.47	100	12.8	7.22	0	0	0	3
	8.13	4440	174.58	100	9.8	7.83	0	0	3	3
	8.73	4680	177.94	100	12.8	8.43	0	0	3	2.3
	9.33	4840	181.11	100	9.8	9.03	3	3	6	2.3
	9.94	5040	189.17	100	11.3	9.64	3	3	6	2.3
	10.54	5240	192.81	100	9.8	10.24	3	3	6	5.3
	11.14	5440	194.11	99.6	7.5	10.84	6	6	5.3	5.3
	11.75	5560	196.14	100	9.8	11.45	6	6	5.3	5.3
	12.35	5720	199	100	7.5	12.05	6	6	5.3	5.3
	12.95	5880	198.06	99.6	10.5	12.66	6	6	5.3	4.5
	13.56	6000	198.36	100	12	13.26	5.3	5.3	4.5	4.5
	14.16	6160	197.08	100	14.3	13.86	5.3	5.3	4.5	4.5
	14.87	6280	196.47	100	14.3	14.47	5.3	5.3	4.5	4.5
	15.48	6440	194.11	100	13.5	15.17	5.3	5.3	4.5	3.8
	16.07	6520	186.75	100	14.3	15.77	4.5	4.5	3.8	6.8
Code:
	Group A:	'118				Group B:	'032
		Engine Speed	Intake Temp	N75 Duty Cycle	Press @ Intercool		Idle Value	Part Throttle Value
	TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	%	%
	0.7	2920	18	94.5	2100	0.4	0	-1.6
	1.41	3200	18	83.9	2540	1.1	0	-1.6
	2.01	3720	18	73.3	2540	1.71	0	-1.6
	2.61	3600	17	0	1770	2.31	0	-1.6
	3.22	3720	15	0	1360	2.91	0	-1.6
	3.82	3720	15	0	1200	3.52	0	-1.6
	4.42	3720	16	0	1060	4.12	0	-2.3
	23.52	2680	21	94.5	1360	23.22	0	-1.6
	24.13	2840	20	94.5	1880	23.83	0	-1.6
	24.74	3040	18	85.1	2540	24.44	0	-1.6
	25.74	3840	18	84.3	2540	25.04	0	-1.6
	26.35	3760	18	83.5	2540	26.03	0	-1.6
	26.95	4000	18	83.5	2540	26.65	0	-1.6
	27.55	4200	18	83.5	2500	27.25	0	-1.6
	28.16	4400	19	83.5	2520	27.86	0	-1.6
	28.76	4600	20	82.7	2460	28.46	0	-1.6
	29.36	4800	21	83.9	2390	29.06	0	-1.6
	29.97	5040	22	84.7	2350	29.67	0	-1.6
	30.57	5200	24	83.1	2320	30.27	0	-1.6
	31.27	5400	25	82	2250	30.97	0	-1.6
	31.88	5560	27	80.8	2200	31.58	0	-1.6
	32.49	5720	28	80.4	2160	32.18	0	-1.6
	33.18	5800	29	0	1510	32.79	0	-1.6
Code:
Group A:	'002				Group B:	'114
	Engine RPM	Engine Load	Ave. Inj. Period	Air Mass Flow		Spec. Load	Load Correction	Actual Load	N75 Duty Cycle
TIME					TIME
STAMP	 /min	%	 ms	 g/s	STAMP	%	%	%	%
0.3	2000	87.2	8.16	38.36	0.61	173.7	171.6	97	94.5
0.91	2080	105.3	9.18	46.11	1.21	178.9	177.6	113.5	94.5
1.62	2240	127.1	11.22	59.83	2.02	180.5	179.1	141.4	94.5
2.32	2440	155.6	14.62	79.36	2.62	181.2	179.1	172.2	94.5
2.92	2640	190.2	17.68	105.06	3.22	182	180.6	191.7	86.7
3.53	2880	191.7	20.4	123.44	3.83	182.7	180.6	191.7	83.1
4.13	3240	191.7	20.74	135.53	4.43	183.5	182.1	191.7	82.4
4.73	3720	191.7	19.72	148.97	5.44	185	183.6	191.7	82.4
5.74	3800	191.7	19.38	149.94	6.04	185.7	183.6	191.7	82
6.34	4040	191.7	19.38	162.83	6.64	186.5	185.1	191.7	82
6.95	4320	191.7	18.7	168.06	7.25	186.5	185.1	191.7	82
7.55	4440	191.7	18.36	174.72	7.85	187.2	185.1	191.7	82
8.15	4680	191.7	18.36	181.36	8.46	188	186.6	191.7	81.6
8.76	4880	191.7	18.02	182.86	9.06	188.7	186.6	191.7	82.7
9.4	5080	191.7	18.02	188.92	9.76	188.7	183.6	191.7	83.1
10.06	5280	191.7	18.02	193	10.37	188.7	177.6	188.7	81.6
10.67	5440	187.2	19.38	192.03	10.97	188.7	174.6	181.2	80
11.27	5600	180.5	20.06	192.39	11.57	187.2	170.1	177.4	79.6
11.87	5760	178.2	20.74	192.69	12.18	186.5	167.2	172.9	79.2
12.48	5880	175.9	20.4	196.14	12.78	183.5	164.2	176.7	78.4
13.09	6040	170.7	19.38	196.47	13.39	179.7	158.2	164.7	77.3
13.68	6160	168.4	17.68	195.28	13.99	175.9	155.2	161.7	75.7
14.3	6280	163.9	17	190.83	14.7	171.4	149.3	161.7	72.9
15	6400	156.4	16.66	190.22	15.39	160.2	138.8	151.9	65.9
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
overboosts, then can't make the boost further up? airflow is low, as you might expect - and the CF's are high.
weird. is the N75 standard?
Who's remap?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
That's not CC, is it?
Timing is nothing special considering the CFs it's showing. As said, too lean for my liking.
You can see in 114 that the ecu is trying to correct the aggressive load.
(Good logs by the way :yes: )
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Who's remap?
Yeah, N75 is standard....could this be faulty?
When you say airflow do you mine the MAF is reading low?
Remap is by a local company in NI.
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
its a bit bloody lean is'nt it? 1.5bar boost and 0.93 lambda??? jeez...
did i read that right??
Dont really understand the lambda bit but if you say it is then Im sure it is.
Best to not drive it or drive it off boost?
There is no faults logged in the ECU...any parts I can check that might be causing this?
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
No not CC its a local companies map.
Cheers....I got what blocks to log from one of your posts;)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
lambda x 14.7 = a/f ratio :1
MAF looks ok, I'd say the problem's the map itself.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Here's an old Revo log of mine...
Actual / Requested.
Code:
3360	0.953	0.938
3720	0.844	0.852
4160	0.821	0.836
4560	0.828	0.836
4880	0.836	0.836
5240	0.821	0.836
5560	0.821	0.836
5880	0.828	0.836
6160	0.821	0.836
6400	0.828	0.836
6640	0.828	0.836
6920	0.821	0.836
6280	0.797	0.836
As you can see, quite a bit richer than yours. *I know that some mappers like to map them a little lean as they come on boost.....
I wouldn't go off what I've said about your timing - unless someone else agrees......
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Anyone offer anymore help?
Is it dangerously lean?....Bill would you want this changed if you seen it coming in?
Do you think the airflow should be more m0rk?
revo carl
104
as everyone else has stated too lean and too much knock!
i'd get rid of that software sooner rather than later; it's even pulling out load at the top end, would be interesting to see the egt's i'd imagine they're rather high!
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Could you explain block 114 to me?
How is the log showing you the ECU is trying to correct itself? What do the % mean in Spec. Load, Load Correction, Actual Load and N75 Duty Cycle?
Kyle
