Had the car remapped and have done some logs to make sure Im getting the best from it....
Ive logged 003 and 020, 115 and 031, 118 and 032. 002 and 114.
I know a little about logging but if someone could take a look and tell me if they think the map could be improved or adjusted in any way.
From the logs boost is peaking at 1.5bar and dropping to 1.1bar, there is a strange dip in boost just around 5k RPM. Is this due to the high CF's?
Let me know
Let me know
Code:
Group A: '115 Group B: '031
Engine Speed Load Cmd Pressure Press @ Intercool O2S1 Voltage O2S2 Voltage
TIME TIME
MARKER STAMP /min % mbar mbar STAMP
4.16 1320 77.4 1240 1070 3.86 0.938 1
4.77 1400 81.2 1280 1110 4.47 0.984 1
5.37 1480 84.2 1730 1150 5.07 1.016 1
5.98 1560 87.2 1860 1180 5.68 1.016 1
6.57 1640 92.5 1960 1230 6.27 0.984 1
7.18 1760 95.5 2050 1280 6.87 0.977 1
7.79 1880 101.5 2130 1340 7.49 1.016 1
8.39 1960 109.8 2240 1420 8.09 0.969 0.953
9.1 2160 122.6 2350 1550 8.78 0.953 0.953
9.7 2280 139.8 2350 1720 9.4 0.961 0.953
10.3 2480 163.9 2360 2000 10 0.945 0.953
10.91 2680 191.7 2350 2420 10.6 0.953 0.953
11.51 3080 191.7 2320 2540 11.21 1.008 0.953
12.11 3560 191.7 2310 2540 11.81 0.922 0.953
12.72 3440 191.7 2300 2520 12.41 0.961 0.953
13.42 3720 191.7 2300 2480 13.12 0.93 0.953
14.02 3960 191.7 2300 2490 13.72 0.945 0.953
14.63 4160 191.7 2290 2480 14.32 0.953 0.953
15.23 4400 191.7 2280 2420 14.93 0.961 0.953
15.83 4600 191.7 2250 2390 15.53 0.961 0.953
16.54 4840 191.7 2260 2380 16.24 0.93 0.953
17.14 5040 191.7 2240 2320 16.84 0.922 0.875
17.74 5240 185.7 2210 2270 17.44 0.844 0.836
18.35 5400 131.6 2180 1660 18.05 0.782 0.828
19.05 5560 131.6 2180 1660 18.76 0.821 0.821
20.06 5720 152.6 2150 1820 19.76 0.867 0.875
20.66 5880 174.4 2170 2170 20.36 0.922 0.914
21.26 6000 173.7 2140 2170 20.96 0.93 0.93
21.98 6120 145.1 2070 1930 21.58 0.86 0.813
22.67 6200 109.8 1150 1380 22.28 0.789 0.766
Code:
Group A: '003 Group B: '020
Engine RPM Air Mass Flow Throttle Opening Ign. Timing Cyl #1 Cyl #2 Cyl #3 Cyl #4
TIME TIME
MARKER STAMP /min g/s % °ATDC STAMP CF CF CF CF
0.28 3320 90.89 100 23.3 0.58 3 0 0 3
0.89 3400 23.42 16.1 9.8 1.19 0 0 0 0
1.49 3400 2.36 5.9 2.3 1.78 0 0 0 0
2.08 3360 5.89 6.3 2.3 2.4 0 0 0 0
2.7 3360 24.39 17.6 35.3 3 0.8 0 0 0.8
3.3 3440 72 34.9 27 3.6 0.8 0 0 0.8
6.92 4040 164.44 100 8.3 6.62 0 0 0 3
7.52 4320 169.47 100 12.8 7.22 0 0 0 3
8.13 4440 174.58 100 9.8 7.83 0 0 3 3
8.73 4680 177.94 100 12.8 8.43 0 0 3 2.3
9.33 4840 181.11 100 9.8 9.03 3 3 6 2.3
9.94 5040 189.17 100 11.3 9.64 3 3 6 2.3
10.54 5240 192.81 100 9.8 10.24 3 3 6 5.3
11.14 5440 194.11 99.6 7.5 10.84 6 6 5.3 5.3
11.75 5560 196.14 100 9.8 11.45 6 6 5.3 5.3
12.35 5720 199 100 7.5 12.05 6 6 5.3 5.3
12.95 5880 198.06 99.6 10.5 12.66 6 6 5.3 4.5
13.56 6000 198.36 100 12 13.26 5.3 5.3 4.5 4.5
14.16 6160 197.08 100 14.3 13.86 5.3 5.3 4.5 4.5
14.87 6280 196.47 100 14.3 14.47 5.3 5.3 4.5 4.5
15.48 6440 194.11 100 13.5 15.17 5.3 5.3 4.5 3.8
16.07 6520 186.75 100 14.3 15.77 4.5 4.5 3.8 6.8
Code:
Group A: '118 Group B: '032
Engine Speed Intake Temp N75 Duty Cycle Press @ Intercool Idle Value Part Throttle Value
TIME TIME
MARKER STAMP /min °C % mbar STAMP % %
0.7 2920 18 94.5 2100 0.4 0 -1.6
1.41 3200 18 83.9 2540 1.1 0 -1.6
2.01 3720 18 73.3 2540 1.71 0 -1.6
2.61 3600 17 0 1770 2.31 0 -1.6
3.22 3720 15 0 1360 2.91 0 -1.6
3.82 3720 15 0 1200 3.52 0 -1.6
4.42 3720 16 0 1060 4.12 0 -2.3
23.52 2680 21 94.5 1360 23.22 0 -1.6
24.13 2840 20 94.5 1880 23.83 0 -1.6
24.74 3040 18 85.1 2540 24.44 0 -1.6
25.74 3840 18 84.3 2540 25.04 0 -1.6
26.35 3760 18 83.5 2540 26.03 0 -1.6
26.95 4000 18 83.5 2540 26.65 0 -1.6
27.55 4200 18 83.5 2500 27.25 0 -1.6
28.16 4400 19 83.5 2520 27.86 0 -1.6
28.76 4600 20 82.7 2460 28.46 0 -1.6
29.36 4800 21 83.9 2390 29.06 0 -1.6
29.97 5040 22 84.7 2350 29.67 0 -1.6
30.57 5200 24 83.1 2320 30.27 0 -1.6
31.27 5400 25 82 2250 30.97 0 -1.6
31.88 5560 27 80.8 2200 31.58 0 -1.6
32.49 5720 28 80.4 2160 32.18 0 -1.6
33.18 5800 29 0 1510 32.79 0 -1.6
Code:
Group A: '002 Group B: '114
Engine RPM Engine Load Ave. Inj. Period Air Mass Flow Spec. Load Load Correction Actual Load N75 Duty Cycle
TIME TIME
STAMP /min % ms g/s STAMP % % % %
0.3 2000 87.2 8.16 38.36 0.61 173.7 171.6 97 94.5
0.91 2080 105.3 9.18 46.11 1.21 178.9 177.6 113.5 94.5
1.62 2240 127.1 11.22 59.83 2.02 180.5 179.1 141.4 94.5
2.32 2440 155.6 14.62 79.36 2.62 181.2 179.1 172.2 94.5
2.92 2640 190.2 17.68 105.06 3.22 182 180.6 191.7 86.7
3.53 2880 191.7 20.4 123.44 3.83 182.7 180.6 191.7 83.1
4.13 3240 191.7 20.74 135.53 4.43 183.5 182.1 191.7 82.4
4.73 3720 191.7 19.72 148.97 5.44 185 183.6 191.7 82.4
5.74 3800 191.7 19.38 149.94 6.04 185.7 183.6 191.7 82
6.34 4040 191.7 19.38 162.83 6.64 186.5 185.1 191.7 82
6.95 4320 191.7 18.7 168.06 7.25 186.5 185.1 191.7 82
7.55 4440 191.7 18.36 174.72 7.85 187.2 185.1 191.7 82
8.15 4680 191.7 18.36 181.36 8.46 188 186.6 191.7 81.6
8.76 4880 191.7 18.02 182.86 9.06 188.7 186.6 191.7 82.7
9.4 5080 191.7 18.02 188.92 9.76 188.7 183.6 191.7 83.1
10.06 5280 191.7 18.02 193 10.37 188.7 177.6 188.7 81.6
10.67 5440 187.2 19.38 192.03 10.97 188.7 174.6 181.2 80
11.27 5600 180.5 20.06 192.39 11.57 187.2 170.1 177.4 79.6
11.87 5760 178.2 20.74 192.69 12.18 186.5 167.2 172.9 79.2
12.48 5880 175.9 20.4 196.14 12.78 183.5 164.2 176.7 78.4
13.09 6040 170.7 19.38 196.47 13.39 179.7 158.2 164.7 77.3
13.68 6160 168.4 17.68 195.28 13.99 175.9 155.2 161.7 75.7
14.3 6280 163.9 17 190.83 14.7 171.4 149.3 161.7 72.9
15 6400 156.4 16.66 190.22 15.39 160.2 138.8 151.9 65.9
