Right I'm trying to work out the mess of wiring in the Ibiza just now. I've made a little digram of how the amp that was in the car when I bought it was wired(Power and Ground were there too)
Does this make sense? I haven't seen a speaker input plug on an amp before I thought they had to run RCAs or is it just better to run RCAs? I assume because nothing was connected to the speaker output of the amp there was 6x9s or a sub connected before?
This is the speaker input plug
And the control from the CD Changer I assume
So if I wanted to run amped components on the front, I can run the same power, ground and control and hide the amp under the passenger seat. Then I can splice into the front speaker wiring the same way or I should I do away with that all together and run an RCA low converter from the HU and then into the amp?
Also anyone know what the hell this is? Found it behind the HU.
Sorry for the long shpeil, I am clueless with anything to do with wiring.
