Car + VCDS = Expensive mistake?
Woll
Just managed to get VCDS on my car. Wasn't a good idea. 12 fault found. I've only got VCDS lite so not all fault code are explained. Can someone tell me what they mean?
VCDS-Lite Version: Release 1.2
Sunday, 20 January 2013, 11:32:33.
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56
Address 01: Engine Labels: 045-906-019-AMF.LBL
Controller: 045 906 019 BG
Component: 1,4l R3 EDC 0000SG 5180
Coding: 00105
Shop #: WSC 06402
VCID: 5BC9146FDA3D
VSSZZZ6LZ5R044688 SEZ7Z0D2460409
4 Faults Found:
19463 - Camshaft Position Sensor (G40): No Signal
P3007 - 35-10 - - - Intermittent
19561 - Shareware Version. To Decode all DTCs
P3105 - 35-10 - Please Register/Activate - Intermittent
18057 - Shareware Version. To Decode all DTCs
P1649 - 35-00 - Please Register/Activate
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 R
Component: ABS 8.0 front H03 0001
Coding: 0000008
Shop #: WSC 06403
VCID: 4CEBE7336FD3
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Sunday, 20 January 2013, 11:34:47.
Control Module Part Number: 6Q0 959 433 E
Component and/or Version: JJ Komfortgerát 0002
Software Coding: 00064
Work Shop Code: WSC 06402
VCID: 3D0DBAF72469
Additional Info: 6Q1959801A JJ Tõrsteuer.FS KLO 0202
Additional Info: 6Q1959802A JJ Tõrsteuer.BF KLO 0202
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00849 - Shareware Version. To Decode all DTCs
25-00 - Please Register/Activate
Sunday, 20 January 2013, 11:47:16.
Control Module Part Number: 6Q1 937 049 D
Component and/or Version: 0000 BN-SG. 1S34
Software Coding: 00012
VCID: 3C0BB7F33F73
5 Faults Found:
00900 - Fuse for Signal Horn (S194)
37-10 - Faulty - Intermittent
01316 - Shareware Version. To Decode all DTCs
49-10 - Please Register/Activate - Intermittent
00778 - Shareware Version. To Decode all DTCs
49-00 - Please Register/Activate
01044 - Control Module Incorrectly Coded
35-00 - -
01598 - Shareware Version. To Decode all DTCs
07-10 - Please Register/Activate - Intermittent
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
Write them down, clear them and see what comes back. Otherwise you could end up trying to fix old faults that are stored in the ecu.
Woll
Yeh that's what I've done. I think the camshaft sensor one could be the intermitten problem i've been having.
Oct 17, 2006
1,015
northwest
Saved you £50 already...
And now you can turn the egr down and log maf/ temp sensor and more = better mpg and more £££
Woll
It was an expensive mistake because of the amount of errors there are. If I have to repair them all it's going to cost a fortune.
Hasn't really I've just found out my mate at a garage could have done it for me for free too.
As far as i know adjusting then egr won't make any odds. A mate of mine blanked his off. Dynod with egr and without egr. Exactly the same hp and torque.
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
Turning the egr down doesn't give more power, it stops the inlet getting bunged up with soot.
n0ble
Newbie
Sep 14, 2006
379
You should clear all DTC and see what comes back.
1 possible cause of many for lots of fault codes is if the battery went flat at any point.
So worth a clear, have a drive and the recheck.
Sent from my Galaxy S3 using Tapatalk 2
