i have yes, the speed is set to the minimum of 0.5kph and maximum of 100kph.I assume you have you set 'Left cornering light (using fog light)' and 'Right cornering light (using fog light)' to ON?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I think there is a setting in the infotainment as well, in the Vehicle menu. Other than this I don't knowi have yes, the speed is set to the minimum of 0.5kph and maximum of 100kph.
I'm the same as you wanting to enable Scandinavian rear DRL's, but don't want it to look like I've turned the lights onto sidelights and have the dash/console buttons all lit up. I'll see if anyone's posted the same question on the OBDeleven forums.When Scandinavian DRL are activated it also changes the interior lights to be on and the sidelight button light to be permanently lit up. Is there anyway to get the rears on without interior.
not sure, i reset the lights in the infotainment and i think that done it. I was driving one night and realised they were workingCool. What was the problem?
Got the Carista today, signed up for beta, what extra functionality does this give?
Anyway, my 2019 290 Cupra had most things switched on by default, i did switch the sound actuator to 0 and switched on the beep to lock
Switching that fake sound off is amazing, can now enjoy the car more and hear the exhaust better!, the fake sound in Cupra mode was so annoying, id recommend this to anyone!
How did you switch the sound actuator off? I got told I can't do it..
Really easy mate, its an option in Carista (doesn't need to be beta of anything)
there is a round dial and can set to the desired volume
who told you, you cant do it?
Wonder if its only available on the lux then
Where is it?it is because ive got non lux and ive turned mine to 0
Found it! I'm unsure what difference it actually makes though?il try get a screen shot later of where it is in the software.
How much does it cost for Carista and the Beta to be able to do this? I’ve just got a cupra lux 290 I want to turn it off on.lol it turns off the fake sound so now any sound you hear its from the exhaust
