Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Activate it in the app then in the mmi sorted
Still not working.. What I'm doing wrong?
Don't wish to be facetious - but I assume you do already have folding mirrors. ie if you rotate the knob on the door (which selects which door mirror to adjust) by 180 degrees - the mirrors do fold.
Yes of course. But I'm looking for the option to auto fold them when locking/unlocking the car
Yes I understand that - but, as you will see from earlier posts on this thread, several of us have managed to get this to work (on Carista betas 3.4 and 3.5 - though I have no idea about the released versions).
Note, however the mirrors only unfold when the ignition is switched on. (A point which irritates my OH)
OK so please can you list here the exact steps you did? From connecting the obd2 plug to testing the feature.
OK but I don't think I did anything odd.
1) Plug in your OBD2 adapter ( remove the panel by the driver's right knee covering the fuse box) I used the cheapest adapter I found on eBay with no problems.
2) Switch ignition on
3) Select Carista ap on your phone and select CUSTOMISE
4) Wait a few minutes - it is slow - while Carista scans your car.
5) You will then be presented with some options Display/lights/mirrors/other. Choose the right one ( can't remember exactly now - but it is obvious and you can select each in turn in any case.)
6) Choose mirror fold on remote press (only short press now available, but long press was) and the other option to display the MMI for this on screen.
7) In each case apply and wait for confirmation.
I hope this helps/works for you.
Does the knob should be on 0 or on the folding mirrors sign?
The knob should be "off". I'm not sure what happens if either mirror is selected, but obviously if it is in the folded mirror position the mirrors will be folded anyway.
OK. Should the engine be on or just the ignition?
ibiza 2017 owner..
I have the carista app version 3.5 beta 2 and I can't manage to make the "Auto fold side-view mirrors (req. power folding mirrors)" to work..
How did you do that?
amitbaz
I have tried getting the mirros to fold with short key press but cant.
Have you tried locking the car and keeping the fob button pressed for about 3-4 seconds, check to see if the mirrors fold in then.
I have checked this with the mirrors in menu option also with the fold mirrors option, as far as i can tell neither give the option to just press the lock button and release it, you have to hold it in.
Gavin
