yeah, seen that pill, but is it necessary to remove brake booster?
No dont remove the brake booster,
another thing cowie, those 19mm red silicone pipes... are they reduced onto the toyosprts can??
that toyosport catch tank looks identical andrews greddy one - we have not fitted it tho as the inlets are around 9mm and we felt this would have a negative effect on gas flow
No dont remove the brake booster,just replace the "Y" shaped connector from the pipe and replace with a straight piece to tidy it up.
Have you unscrewed the inlets mate,the toyos are 9mm and 14mm,just turn them round to suit your pipework
but the y piece bit goes under the inlet manny for vacuum to the brake booster... from a nipple under there
Phillc,
Sorry for being a pain and probably asking stupid questions but this brake booster is one thing im still not sure about.
Take a look at this picture
Number 23 is an elbow that comes off the bottom left side of inlet manifold. As i understand number 25 is the pipe that goes to brake booster. Number 22 is suction pump or something like that. Do you mean that i can get rid of number 22 and put a straight silicone over there to connect it straight to brake booster? Number 24 goes to pcv valve and will be removed. I think ... ;p
