after finding another stupid bolt i managed to re fit my stat.......what a pain in the arse to fit the bottom bolt(well i found )
new seal and the stat.this is how i blead the system all is good no leaks or nothing heaters working hot as well.a
guide how i did it mate.....
ENGINE OFF
1 take the cap off
2 fill the coolant tank up
3 squeese the bottom hose
4 blow into the tank a few times(you will hear it burping air leaving tank)
5 re fill the coolant tank
CAP STILL OFF
6 start the engine
7 heaters on cold full power
8 let the engine run for 5 mins or so (might burp abit)
9 turn off the engine for 2mins or so (some more air still might leave the coolant tank,burps)
10 re fill the tank and start the engine
11 still leave the heaters on for about 10 mins/then turn on the heaters on it should be warm.
12 check the top hose is warm & the coolant.
once all this is done i topped it up drove around for a abit (5mins or so) and the temp guage risen up to the 90dgs mark.
tbh mate if your heaters are warm and top hose is warm and the temp guage is working as normal then your stat should work.yet again i very dought you would/should get any leaks after the drive as there is only 2 clips you take off(bottom hose and top hose where the stat is)
i was having my small leak where the stat was small drips(seal was fooked)
long winded i know im just getting use to working on the seats my self we all learn mate some how normally the hard way like me and a stupid bolt
hope your
problem is sorted out mate.
