teeth2k
908
sussex
i have ran vag com and found this fault
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 037 906 024 BE
Component: DIGIFANT 3.2 2121
1 fault found
00522 engine coolant temp sensor (g62)
27-10 implausible signal intermitant
readiness n\a
i have changed the coolant temp sensor and ran vagcom again only to find the same results .
any help please?
i have been told to clear the faults but im not sure how to do this ~(i have a shareware version of vag com)
You can clear faults with the shareware version of Vag-Com. You have to go into each module where there is a fault to do it. In your case, go into 01, Engine. Then click fault codes. Then Clear Fault codes.
