Derek
119
Kirkmuirhill
Got out of the car yesterday for about 30 mins without locking it, keys still in the ignition. When I got back in and started it the climate control screen was flashing with everything on the screen at the same time. I took the keys out, locked the car and tried again but same problem. I got rid of it by pressing all 5 buttons at the same time. Any ideas???:confused:
sounds just like what my mum's company pug 407 does! but i wouldnt expect it from a seat! probably nothing, just having a funny 5 mins, my stereo on the Ibiza was a bit weird sometimes til i got my alpine, its if it keeps happening then you'd look into it i guess!
I had that a few weeks ago, I think it must have been down to a low battery voltage as I had the radio on all afternoon without the engine running, it reset itself after a bit of a drive.
Low battery voltage where you left it with the key in and turned. :think:
Did it start ok after or was it a bit sluggish to start?
No it started first time, the radio was on all the time I was away as my better half was in the car at the time while I was working. It was pouring with rain and blowing a gale maybe the car was just upset:p
with it being cold I haven't run the air con for some time, will check when I go out in it later, I usuallly run it every few weeks to keep the system running ok like the manual says to. Halfords air con in a can any good or go professional??
My climate control does this nearly everytime i turn my ignition on. Do you use your air con much? If not use it and see if it does it then.
If not, look straight out the windscreen for 30 seconds while turning on the ignition, then look at the climate control after 30 seconds and all will be fine. Works with mine anyway.
I had mine regassed and it didnt solve this problem...
I had this and so checked it with Vag-Com and there was a fault. Had a pressure switch replaced under warranty.
