climate control
flares
355
newport,south wales
I`ve bought another climate control unit as the lcd screen on mine has bled in , has anyone had one fitted if so how much ? . At the moment I have`nt got the time ( OR THE PATIENCE ) to attempt it myself
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Out of interest how much did it set you back?, I don't think they are that hard to swap out. I'm sure I seen a guide for it.
Balf2k
208
South East Kent
Never done it but I should think it's only a 15minute job mate. (I removed the one in my Golf MK4 so would imagine it's pretty much the same). Remove the fascia then IIRC there are torx drive screws either side that hold the climate unit in. Slide it out and unplug it, it really was easy.
flares
355
newport,south wales
I paid £58 on ebay , I was bidding on one b4 that and it went for about £80 . I`ve been struggling to find one locally , the only one was £75
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Some info from Pete.
Open the ash tray and there's a screw at the top. Then when you take the ash tray out there's two screws behind it. Then pull the HU out and remove the two screws you see at the sides. Then the front facia comes off the clips. The air con control is then screwed in with 2 screws.
Thats a good price, even £80 would have been cheap. They are at least a couple of hundred new I think.
