Cold Side Diverter Valve Relocation Kit Worth doing or Not?
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Have been thinking of doing this mod for a while now but would like to hear your views on it first.
Forge's Cold Side Diverter Valve Relocation Kit .
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
From a technical point of view, feeding the DV cold air instead of hot air can't be a bad thing. I didn't detect any changes after I did it, only that having the DV at the front of the engine bay makes it a lot easier to get to for servicing.
9,335
South Wales
I thought it made the DV response slower. Took mine off a while ago as it looked messy and didnt really do anything. Deffo not worth the price tag either, just make one yourself if you wanna do it.
Wilko
Badge snob
I find it odd that you guys found that, as it improved gear change boost recovery noticably on mine.
The cold air side of it is no benefit. To me it's the fact that the air is moving from turbo to throttle body. When the dv opens in the usual position, the pressure wave has to travel the other way to relieve pressure and must cause some turbulence at the take off point (turbo outlet).
With it relocated, the air keeps traveling towards the throttle body, and relieves at the pressure block (throttle body)
On high boost applications, closing the throttle body when boost is building doesn't cause the usual hickup as the boost pressure is relieved.
Much smoother.
The fact that the valve runs colder also means that it needs serviceing less often.
Good mod imho
