Coolant and heating issues
May 4, 2023
Hi,
I hope you don't mind me jumping on this post. I seem to be having a similar issue and am in need of some advice.
My blowers (internal car fans) aren't working at all. I get no air out of the fans. I'm aware it's due to a blocked heater matrix and a few parts need replacing. I'm getting silly quotes of £1500-£1800. I think they may be taking advantage of me being a single female who doesn't understand cars much.
I want to get the expansion tank and a new heater matrix changed and any clogged pipes replaced and then the system flushed. Does anyone have a list of the parts a garage will need? I just want to make sure they're not ordering parts I won't need and doing work beyond that which I've requested.
(I have a 2013 Seat Leon S TDI)
Thank you.
BillyCool
759
326
Leicestershire, UK
Hi,
Thank you.
If your fan is not even blowing air, that is not down to the heater matrix. The matrix is effectively a little radiator that warms the air when requested. The fan provides the air. The air blower/fan is under your glove box. I'd try to get that working before you look at the matrix. It could just be a fuse or connection.
Ref the parts and cost for the matrix. You need the matrix c.£80 and an expansion tank c.£40. You shouldn't need to replace any other pipes.
SEAT quote about £1300 as their service schedule says 8 hours as they remove the dash. If you find someone who is handy with tools, you can do the DIY fix in 2 hours and the cost of parts. It cost me £120 and 2-3 hours of my time. If you can find someone who can do it, it will save you loads of money.
This is a guide I wrote based on info from this forum and my own experience changing my matrix. I'm not saying that you do it, just find someone who can!
  • SEAT Leon TDi Heater Matrix replacement.pdf
Reactions: Walone and Sammie
May 4, 2023
Sorry, I should’ve made it clear that I get no hot air out the vents inside the car. All I get is cold air (despite being on the hot setting).
Is it still a blocked matrix issue?
BillyCool
759
326
Leicestershire, UK
If you're fan is working but just blowing cold air, even on hot, then it could well be your matrix.
If you find a local reliable mechanic they should easily be able to do the DIY fix and save some £££'s.
OVB
Oct 3, 2025
9
Hello, sorry to jump on this thread but have seen this one and another that you @BillyCool have helped on. My situation is very similar to blowing out coolant when the engine get hot. normally only on journeys over 1.5hrs. nothing happens with smaller trips. the heater does get hot on the drivers side but as you feel more to the left it get cooler and cooler until the last one passenger side isnt hot at all. the only thing that is different is - they did the sniff test and it came back positive for exhaust gasses in the expansion tank. so my questions is could this be old and nothing to worry about or could a blocked heater matrix potentially cause this to happen or link to something else to make that happen. the garage have said they believed initially it could be a egr cooler or head gasket and sent me to a VW engine specialist who want to bleed the system for airlocks first. sorry for the long message but i welcome any help as cost me hundreds already. also for note - it doesnt overheat on the gauge in the car, no white smoke, passed pressure test, passed pressure test on cap and expansion tank itself. pipes that can be reached arent solid with pressure and oil appears fine. thanks
Compo1
337
89
Exhaust gas detection means 1 of 3 things
Charge cooler
EGR Cooler
Both can be bypassed for testing purposes
Head gasket.
But as you have no hot air on the passenger side Heater matrix also.
BillyCool
759
326
Leicestershire, UK
It's hard to say. Usually, the blocked matrix causes reduced heat on the drivers side. This is becuase the pipes attach to the matrix on the left and the loss of heat is felt more on the drivers side. It could be the matrix causing that or maybe issues with the heating servo and flaps?
The coolant loss when driving with a blocked matrix happens when the car does a DPF regens and boils the coolant in the matrix circuit and this usually vents from around the expansion tank lid. When you say blowing out coolant what do you mean? Where from?
The car is known for EGR coolers to fail. That won't explain the loss of heating but is a known reason for coolant loss. They are also a pain to access and replace. Not sure if that would cause exhaust gases to be detected in the coolant. A failing head gasket would cause loss of coolant and exhaust gases to be detected.
You could have more than one issue and that makes it harder to diagnose. I am sure other, wiser people than me can offer their thoughts.
You could replace the matrix and see if that helps with the cabin heating and coolant loss. If not, then you have other issues.
I can't really offer any more help than that. It would help if you can confirm what car/age/engine.
OVB
Oct 3, 2025
9
Charge cooler
EGR Cooler
Head gasket.
Hi
So would the first place to start would be heater matrix?
But could a blocked heater matrix also cause something to push gasses back into coolant? I know it shouldn't be the matrix directly but not sure if I'm ready right that it could cause this.
The head gasket there are no other signs although I appreciate that you might not see anything with these more modern engines.
The issue with the egr cooler is it's location and it's quite timely to get to.
That's why they want to bleed the system as a starting point?
OVB
Oct 3, 2025
9
Thanks for your reply. I understand what you are saying. I read the coolant could be based on the matrix.
The coolant is coming out through the overflow on the expansion tank.
It's a seat tarraco 2019 dsg 2.0l. VW engine I believe.
The garage want to bleed the system as been open a few times so want to rule out air but as you said it doesn't explain the gasses in the expansion tank. I've only had the car 10 months but could this have been something old perhaps.
They have said this engine typically doesn't have head gasket issues but has had EGR cooler issues. Really hard one as neither fix is cheap!
Compo1
337
89
Hi
A blocked matrix wont cause exhaust gases in your coolant. But it sounds like you have a matrix issue also, as what you describe is classic blocked Matrix.
I'd start by bypassing the charge cooler coolant pipes first drive it for a week and re gas test it, if the gas test is now negative the charge cooler has a leak. You could even put a bore scope in there to look for coolant.
Then id bypass the EGR coolant pipes and retest and at that point if your still positive for gases its the Head gasket.
Head gaskets are not that common a problem on the diesels, though.
OVB
Oct 3, 2025
9
Thank you for this. I'll have a chat with the garage on Monday when the car goes back in and report back. Thanks
Reactions: Compo1
SuperV8
1,924
985
How often are you loosing coolant out your header tank overflow? Is it suddenly all gone from being full, or does it gradually reduce over time?
If only occasionally, in one big dump & in time with a DPF regen then this is a common sympton of blocked heater matrix. If you pull the lower trim pannel off to reveal your flow and return pipes to the heater matrix you can feel these with your had. The flow should get hot within a minute of starting the engine, and the return will slowly get hot. The reutrn should be slightly cooler than the flow (if the matrix is working and moving heat into the cabin) - if both are the same temp, then that is also a symptom for a blocked matrix.
The exhaust gasses in the coolant is more concerning - Following this postive result I would ask for a leak down test, to rule out head/gasket issues, though this can be tricky as sometimes a small leak may only be present on a hot engine, and not when cold.
Hopefully not the case - but maybe the previous owner was having coolant loss issues and used some 'stop leak' junk which can block your matrix and other small passegeways.
OVB
Oct 3, 2025
9
Thank you for coming back to me. In answer to your question the coolant loss isnt massive. i have attached an image. it will only lose it out of the coolant expansion tank when i have driven for over 1.5hrs. it runs under the tank also. so its not huge leaks!
i will look at the pipes you have mentioned.
the garage havent done a leak down test. they have done a compression test and it held pressure. the car is fine when driving anyway for around an hour and doesnt do it even when taking it to higher speeds.
they have pointed to wanting to do a bleed test to make sure no air in there, its due a cam belt and water pump which they said to do but i explained to them i dont see how that would solve exhaust gasses in the coolant. they then just come back to EGR cooler which has been common on this 2l engine. if they did use the stop leak stuff then the bleed test should show an air lock or full block i would have thoughts?
there is the option of egr bypass and see if gasses in the coolant as long as they add new coolant to get a true reading? i am just a bit lost at where to start to be honest as already spent money to end up actually being no where!
appreciate your help and thoughts
SuperV8
1,924
985
How old is the coolant cap? Replace it with a new one would be my advice. In the end its a mechanical component (spring loaded).
My cap was weak when I tested it, when I was fault finding ultimayle having matrix issues - it leaked at around 10-12psi from memory vs the rated 24psi.
This blue circle is the overflow - If the system over pressurises and the cap vents, any coolant should vent out this spout. I would see a puddle of coolant on the metal work below this spout.
When my matrix was partially blocked - I would only get heating on one side, as the blocked area of the matrix had no coolant flow so no heat flowing. The cabin heating is divided into two areas direcly on top of the matrix which is why you would only get half heating in the cabin if your matrix is partially blocked. You could get the same effect with an air lock - but normally this would resolve its self over seveal weeks.
The heater matrix in on its own mirco cooling circuit with the EGR cooler with its own electric pump, during and after a DPF regen there is a hugh amount of heat dumping into the cooling system - a restriction in the matrix and the mirco circuit causes local boiling and over presurisation which for me would go from full to min on the header tank in one event.
It's not unheard of for the main coolant pump to leak - obviously would be an external leak, you might see dried coolant residue on the underside of the engine on cambelt end.
Don't think of the money you have spent as a waste - it is unfortunatly needed to try to diaganose a complicated issue. Modern cooling systems are very/too complicated!
OVB
Oct 3, 2025
9
Thank you for the detailed reply. It does make sense what you have said.
I think I am going to do the cam belt and water pump as its due, have the system fully flushed (including heater matrix) and airlock checked, replace the EGR cooler which 3 garages have said they believe is the fault (exhaust gasses in coolant) - all of them have said it has been common in this engine. head gaskets in this one they have all said are rare. then drive it and test the coolant for exhaust gasses again.
the matrix is a funny one as the only one which doesnt get hot is the passenger one. all the others do. but i am hoping this isnt the cause and a flush/clean might sort this out. as that doesnt explain the gasses in coolant as far as i am aware?
i have been told that to bypass the egr will cost money to open it up, bypass, put back together, drive it, test, then take apart to stop bypass/change egr then put back together. so might have to take a hit on that one.
sorry for the long message but hopefully it makes sense?!
SuperV8
1,924
985
Sounds reasonable.
Regarding flushing the matrix, I tried this 5 or 6 times - hypothesising that each time what ever was blocking it would reduce in the system - long story short it didin't. It would work for a month or two, then partially block again!
I changed the matrix (after fully flushing the sytem when I did my cam belt and pump) and it has been fine for years since.
On the Leon a matrix change is quite simple - don't know how the Tarraco compares? - If simaraly simple, no harm in doing the belt and pump and flushing the system - and 'see how it performes'? and then possibly change the matrix at a later date.
Reactions: nd-photo.nl
OVB
Oct 3, 2025
9
Sounds reasonable.
this is kind of where i go with it. i think i will do the full drain and flush, change the cam belt and pump and do the egr cooler at the same time.
i checked the pipes as you said and one gets warm quickly and the other warmer slowly.. its a hard one to test as 3 of the 4 heaters on the front are nice and warm. its just that far one! i believe its relatively easy to get at so might park this one for now and see if the flush does anything for now.
its the cooler thats the costly part as the other items dont help with exhaust gasses in the system. apparently the egr coolers on this model are quite common!
