I got there
.. Cruise control fitted DIY with VAGCOM to activate on Cupra Tdi
Used Erwin to make sure of wiring .. but it is all doable .. the biggest problem I had was getting the crimps/terminals to insert in the plugs. Wurth sold me some as this is who the dealers/aftermarket buy their crimps from.
Anyone want to know.. or is this old news?
.. and how do you get the instrument panel out of these cars .. if you could do that then maybe you could do a totally splice free job .. need to get to the big multi connectors at the bulkhead from the inside .. you cannot get to this internally from on the outside at the windscreen wipers unlike some Golfs. I spliced to the white ECU here and then put the wire through the spare empty socket. Got power from the right fuse off the back of the fuse board by a splice .. the rest is plug and play .. and if you could get to the back of the bulkhead connector you would get the ECU wire plug in (need to ID the crimp first..).. and maybe that is where the fuse board feed is.. looks like it might be.
Issues... remove the light switch from the panel before you pull the panel off by removing fuse board on dash end .. I managed to break the light switch
.. and the panel over the wipers below the windscreen is a tricky bit to get off .. well more tiresome as you have to put bonnet up and down 3-4 times to make sure it is right.
Connector dealers/vans = www.wurth.co.uk/contact.php
Stalk connector = 0558-190-22
Central control connector = 0558-190-13
Need new double stalk
Need brown XS3 plug
.. Cruise control fitted DIY with VAGCOM to activate on Cupra TdiUsed Erwin to make sure of wiring .. but it is all doable .. the biggest problem I had was getting the crimps/terminals to insert in the plugs. Wurth sold me some as this is who the dealers/aftermarket buy their crimps from.
Need brown XS3 plug
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
priceless
