dErZ
203
Surrey
Was checking my front suspension today and my rear bushes are split and there is sooooo much movement in the front wheels.
Is the part number I need to upgrade to the Cupra bushes 6LL 407 183 ??
I couldnt find any play in the front part of the tca but can anyone advise of the part number for the front bush please.
Also does anyone have a part number for the rear suspension struts? left and right please.
Cheers ash, did you get the front one done too? I dont want to take it to bits and then find I need the fronts or anything else around there!
The front bushes arent available seperately, Powerflex do them though.
Not a massive difference but if you have them apart anyhow why not.
I only did the rear ones on the front wishbones.
I found it easier to remove the console from the sub frame & press them in from the back than rather the front otherwise you will need a insert to push them to the rear of the console.
Worth the effort though.
How I drive em out...
I keep a supply of consoles ready done and just swap them over.
The original type bushes have been deleted now, if you order non cupra bushes you get the MK2 Leon bush to put in.
Yeah looks like it, not seen one on its own before. However I doubt there is anything wrong with your ones. Powerflex offers something a little stiffer over standard thats about all.
and so you know, the Powerflex front wishbone bush is the same as a MK2 Golf so may help if you looking on ebay.
