cupra dies and comes back to life
SNOWZ
106
Hereford born and bred
all sorted now, was the speed sensor bought one from the dealers for about £80 and had it fitted for £10 so not too expensive.
its een a week now and all is well, for now anyway:lol:
MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
I've got the same symptoms:
Driving along normally then suddenly cuts out, it'll just turn and turn but not fire. Then if you leave it for 10 / 20 mins it'll start up fine for another mile or so.
Found 3 faults on VagCom:
3 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16501 - Engine Coolant Temp. Sensor (G62): Signal too Low
P0117 - 35-00 - -
Readiness: 0010 0000
Have already changed the Coolant Temp Sensor, and thought I'd cured the problem but it happened again so next I will change the Engine Speed Sensor (G28).
Anyone know what:
Could this be where I had been trying to start it, draining battery?
Will let you know how I get on.
Mike
jattjoka01
109
London
THE BATTERY TERMINAL MITE BE LOOSE...exact same problem happned to me ...ocassional ...but no difference in boost or performance..i went to the garage...i fort i would of needed a new battery but the battery still had a charge...so i asked the man to look at it..turns out my battery terminal was loose although it would geta spark it wasnt tite enuff so it would move occasionally extinguishing the spark hence car would cut out.. so chek it out!! mite be the problem !!! !!
