Cupra engine mounts
Shock_Xe
not easy, garage/ramp jobbie for rear and box mount (box has to come out)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
eh?? :confused:
no it does'nt...
g'box mount is lift it up a bit off OPE mount, drop in new one and lower it down. Front is fiddly (access to bolts etc) need to support motor, again jack it up remove/refit, and rear is same again.. lift it up & possibly removed rear mount off block (x4 bolts only)
not a g'box out job, unless that was being done for another job like clutch etc
Shock_Xe
ibizacupra said:
eh?? :confused:
no it does'nt...
oh well me being thick, cause I had my clutch done same time, from what fitter was saying box had to come out to change mount :doh:
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
if clutch being done then yea.. easy as.. seeing as its all coming out.
Not req'd.
I know I did'nt remove mine when I fitted em.. just jacked motor up off mounts, replaced them and sat it back down again. Not a 10min job mind you.
