very short guide to bumper removal: (with a search there are lots of guide about)
undo front side of front wheel arch liners.
pull liner back and look inside bumper.
undo 2 bolts each side.
pull out the two lower font bumper grill. (not the middle one). there may be a screw to undo but i think they just clip in.
inside both of these there is a bolt to undo. (those that need the star shaped heads.
pop bonnet.
the front bumper is now only attached via the top grill to the front panel.
there are 4 (i think) bit that are joined to the dont panel by push fit plastic clips.
using a flat screw driver remove these but simply lifting vertically.
(note it may not but the bumper will not be held securely to car at this point so get someone to hold it).
if it hasnt already come away, pull the bumper horizontally forwards of the car.
(the undertray may catch on the bumper a bit as it slips onto the bottom of the bumper.
bumper should come off.
you can work out refit yourselves im sure.
if you are changing from LCR to LC or LC to LCR then the shape of the bumper is different and therefore the wheel arch liners will no long mary up. so you need to change the arch entensions to accomodate the new bumper.
have fun.
